Need some input
Discussion in 'Other Toyota Vehicles' started by Grumpy Uncle, Apr 19, 2018.
  1. Apr 19, 2018 at 5:37 PM
    Grumpy Uncle
    Grumpy Uncle [OP] Pushing string down the hall SSEM #10
    Pat
    CO
    So my boys 97 T4R, rear lift door wont open. I have tried the handle, the key. I have tried jarring the door. Does anyone have any ideas on how I can troubleshoot this. I can't even open it to troubleshoot it. Thanks in advance.:notsure:
  2. Apr 19, 2018 at 5:49 PM
    Can you get inside and remove rear lift panel????
  3. Apr 19, 2018 at 5:53 PM
    Grumpy Uncle
    Pat
    CO
    I looked if there was a way I could remove the panel. I don't see a way I can take it off to get to the moving parts. Here in a little while I am going to go get a Haynes manual because the Chilton doesn't have anything about the latch mechanism. I am stumped.
  4. Apr 19, 2018 at 5:54 PM
    I wonder if the Gr8t one, Connor might have some insight????
  5. Apr 19, 2018 at 5:55 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    You might have to get to the lock from the inside. Not sure if that's even possible to remove the trim with the door closed. The idea is to get to the lock and somehow unlock it. Here is the diagram. I hope that helps.
  6. Apr 19, 2018 at 5:56 PM
    Grumpy Uncle
    Pat
    CO
    This beer is making think creatively though!
    Dremel, a hole and if needed a bigger hole, then go to the pull and pay for a new panel.
    boostedtrdpro and Black Wolf like this.
  7. Apr 19, 2018 at 5:57 PM
    Grumpy Uncle
    Pat
    CO
    Kind of what I was thinking, I will IM him in a little bit. The ball game is getting good!
  8. Apr 19, 2018 at 6:01 PM
    Grumpy Uncle
    Pat
    CO
    Thank you kindly, sir. His Chilton doesn't even have that. I need to have the hatch open to remove the panel. I'm hoping the Haynes has something.
  9. Apr 19, 2018 at 6:01 PM
    and the brewskies...............
  10. Apr 19, 2018 at 6:02 PM
    nk1794
    San Jose, CA
    Have you tried and spray some WD40 inside the lock cylinder?
    Grumpy Uncle[OP] likes this.
  11. Apr 19, 2018 at 6:04 PM
    Come to think of it the new 4R's are kind of nice.........:cookiemonster:
  12. Apr 19, 2018 at 6:04 PM
    Grumpy Uncle
    Pat
    CO
    Again thank you for the tech sheet. I'll try to see if I can go in through the licence plate area. Like in the drawing.:thumbsup:
    nk1794[QUOTED] likes this.
  13. Apr 19, 2018 at 6:06 PM
    Grumpy Uncle
    Pat
    CO
    Those too. I have a grinder, hammer and a welder. I can fix anything..
    831Tun likes this.
  14. Apr 19, 2018 at 6:07 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Grumpy Uncle[OP] and nk1794 like this.
  15. Apr 19, 2018 at 6:08 PM
    Grumpy Uncle
    Pat
    CO
    Yes sir, I even put a socket over the lock and gave it a couple of taps with a rubber mallet, trying to jar it loose.
  16. Apr 19, 2018 at 6:08 PM
    Pepe Sylvia
    Pepe Sylvia New Member
    2013 Magnetic Gray Metallic??? Sr5 TRD
    NASA, yet...
    Does the window go down? Maybe you can gain access to the cable, I did something similar in my 04 Seqouia.
  17. Apr 19, 2018 at 6:11 PM
    Grumpy Uncle
    Pat
    CO
    Yes they are! Got one for the wife, I wont get one for a 16 year old knuckle dragging, hormone psycho teenager.
    831Tun and Black Wolf[QUOTED] like this.
  18. Apr 19, 2018 at 6:13 PM
    Grumpy Uncle
    Pat
    CO
    Beer has made my Google Fu weak this evening, thanks.
    Thats why I love this site, great people helping out.
    JoshuaA[QUOTED] and Black Wolf like this.
  19. Apr 19, 2018 at 6:14 PM
    Yep...That would be crazy...
  20. Apr 19, 2018 at 6:14 PM
    Grumpy Uncle
    Pat
    CO
    Yep it does, I'll try that too. Thanks.
  21. Apr 19, 2018 at 6:15 PM
    nk1794
    San Jose, CA
    If all else failed "C4"
    Black Wolf and Grumpy Uncle[OP] like this.
  22. Apr 19, 2018 at 6:16 PM
    Apparently quite a few of us here don't have much else going on tonite.......:confused:
  23. Apr 19, 2018 at 6:19 PM
    nk1794
    San Jose, CA
    We saw the distress signal.
  24. Apr 19, 2018 at 6:19 PM
    Grumpy Uncle
    Pat
    CO
    Playing hooky tomorrow. Finally making the pilgrimage to TOYTEC in the morning. Also watching the Yankees and Jays.
    Black Wolf likes this.
  25. Apr 19, 2018 at 6:25 PM
    Picking up your OME goodies for the Runner?
  26. Apr 19, 2018 at 6:27 PM
    Grumpy Uncle
    Pat
    CO
    Yep, yep. I don't know who is more stoked, me or him.
  27. Apr 19, 2018 at 6:29 PM
    Equal stokage.....Somehow I have an inkling when you walk thru the front tomorrow morning and see all the various goodies on display...........................:spending:David....
  28. Apr 19, 2018 at 6:32 PM
    Grumpy Uncle
    Pat
    CO
    You know there is allllways extra stuff that needs to be liberated.
    I forgot:spending::spending:
  29. Apr 19, 2018 at 6:34 PM
    There are free decals/stickers you can get. Will look good on the Runner.
  30. Apr 19, 2018 at 6:39 PM
    Grumpy Uncle
    Pat
    CO
    I like free... I will definitely get some hats and maybe some t shirts and tell Mrs. Grumpy we were lucky customer # 37 that day.
    831Tun and Black Wolf like this.
