Need some Help 4wheel drive when i press
Discussion in '1st Gen Tundras (2000-2006)' started by batwrangler, Sep 18, 2021.
  1. Sep 18, 2021 at 7:56 AM
    batwrangler
    batwrangler [OP] New Member
    Bat
    na
    na
    the 4 wheel drive button it just blinks it is not going into 4 wheel it has not been used much all summer ,,any ideas
  2. Sep 18, 2021 at 8:20 AM
    AZBoatHauler
    So.Arizona
    Best chance to get it to engage is to slow speed roll and give it some gentle turns of the wheel back and forth. What’s the history? Year, mileage, and was it used on a regular basis leading up to this?
    NewImprovedRon likes this.
  3. Sep 18, 2021 at 8:36 AM
    batwrangler
    Bat
    na
    na
    its an 05 135000 slow speed turning wheel does not work ,,i did not use it thru the summer ,,now i found that when i push the button light on dash blinks ,,4 wheel is in light stays blinking ,i tried to spin tires in dirt ,press button light is off ,,rear tires spin easy ,,im thinking maybe its not going in all the way??
  4. Sep 18, 2021 at 8:40 AM
    AZBoatHauler
    So.Arizona
    The actuator is what tends to be the problem when this happens. Failures occur most often after long periods of not engaging 4WD. You can try tapping on the actuator to see if you can work something loose. If that doesn’t work, do a search on here and you’ll find threads where people have taken them apart to fix them if you’re inclined to try that.
  5. Sep 18, 2021 at 9:16 AM
    batwrangler
    Bat
    na
    na
    ok ill try that thanks
  6. Sep 18, 2021 at 10:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    also check for wiring damage- since it has been sitting it is possible a rodent has chewed some wires.
    2mchfun likes this.
  7. Sep 18, 2021 at 11:53 AM
    batwrangler
    Bat
    na
    na
    ok..is their only one actuator ,,the guy in the store asked me ,,,Is it the front actuator or the transfer case actuator?Not sure i think the guy at the counter was wrong ill bring the part their and match it up
  8. Sep 21, 2021 at 3:52 AM
    batwrangler
    Bat
    na
    na
    Is their a front differential actuator and a rear transfer case one? im confused
  9. Sep 21, 2021 at 3:57 AM
    TrashcanBand
    TrashcanBand New Member
    CenTex
    Tundra
    If 4WD isn’t engaging then you’ll be looking to troubleshoot an actuator in the front.
  10. Sep 21, 2021 at 8:27 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    Fyi, after long periods of non-use I've had my 2007 take 10-15 mins of driving for 4hi to engage.
    Rodtheviking likes this.
  11. Sep 21, 2021 at 3:25 PM
    batwrangler
    Bat
    na
    na
    im going to try that 15min drive too ,,Is their any way to find out for sure its the front actuator ..i push button in and it blinks ,,while engine running if i push button in and look under their what should i see (drive shaft turning or not turning )
  12. Sep 21, 2021 at 3:35 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    This is why on my 05 4runner I would make sure to engage it once a month, common issue.
  13. Sep 21, 2021 at 4:56 PM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    If your long drive doesn't work then come back here and search the 1st gen section for troubleshooting info. Chances are there's pretty good data on here.
  14. Sep 22, 2021 at 7:35 AM
    batwrangler
    Bat
    na
    na
    I did look up gen 1 on this site great info,,,I still didmt take the drive yet but I did turn trans for case drive shaft turns easy then i turned inj on press 4 hi button ,,it blinks ( transfor case drive shaft doe'nt turn so i think now its my axle actuator an i wright?
  15. Sep 22, 2021 at 8:19 AM
    batwrangler
    Bat
    na
    na
    Got it guys knock the axle actuator with a hammer it started to work ,,i lock it in and out about 10 times and it works ,,,great site saved a ton of money i will donate to the site thanks ,,,
    shifty` and AZBoatHauler like this.
  16. Sep 22, 2021 at 8:48 AM
    AZBoatHauler
    So.Arizona
    Glad tapping on it broke it loose. Always a good day to save $1,000.
    shifty` and batwrangler[OP] like this.
  17. Sep 22, 2021 at 8:49 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    good % of the time, the bomping does it every time. Exercising 4wd, moonroof, very back window, etc periodically to the maintenance schedule very much recommended !
    batwrangler[OP] and des2mtn like this.
  18. Sep 22, 2021 at 9:03 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I will send you my PayPal info.
    Tundra2, shifty`, N84434 and 2 others like this.
