Need some advice on wheels n tires
Discussion in 'Wheels & Tires' started by 559trdTundra, Apr 20, 2022.
  1. Apr 20, 2022 at 9:21 AM
    559trdTundra
    559trdTundra [OP] New Member
    So I just got some 295/70/18 Falken wildpeak AT3W that I was going to install on the 17’ TRD pro wheels, but now I’m deciding to get some new FN BFD wheels to go with the Falken tires , what size FN BFD wheels do I order?? 18x9 ??
    where do I order those wheels and where’s the best price?
    My TRD pro wheels are 18x8 I believe
  2. Apr 20, 2022 at 9:23 AM
    559trdTundra
    Also with the 295/70/18 and FN BFD wheels, are there going to be any rubbing issues? I’m still on stock TRD suspensions
  3. Apr 20, 2022 at 11:33 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    rubbing will depend on your lift and what backspacing on the rims. stock OR package wheels are +60 offset. So you need to check and see what the backspacing/offset is for the wheels you want. Generally +18 to +35 will fit well, have less rubbing issues vs. rims with more negative offset.
  4. Apr 20, 2022 at 9:47 PM
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    I replied to you in the other thread, but this was a set of 18x9 BFDs on 295/70r18 Wildpeaks that sold. You can see it sticks out slightly less than the photos of BFDs in the other thread since these are the newer +18 offset version that are now flow formed vs cast (and therefore stronger):
    https://www.tundras.com/threads/fs-18’-fn-bfd-with-falken-wildpeak-at3.99738/
    And here are photos of another member with a stock Pro with BFDs and 295s, but different tires. The Wildpeaks look better to me, and I wouldn't run the center caps:
    https://www.tundras.com/media/albums/main.1392/
    It's tough to beat the stock Pro wheels that are forged and 27 lbs. But the BFD is only 22-23 lbs, one of the lightest 18" wheel you can buy for the Tundra.
    As you can tell, I seriously considered this wheel before deciding on 17" Titan 7 wheels.
  5. Apr 21, 2022 at 9:23 AM
    559trdTundra
    Mike thanks for your response, another question is will the stock TPMS sensor Transfer over to the BFD wheels ?
  6. Apr 21, 2022 at 9:35 AM
    pvmike
    Los Angeles
    Yes sir.
  7. Apr 21, 2022 at 10:03 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    With the emphasis on "less rubbing issues". I personally am not cool with ANY rubbing.
    The +20's with tall skinnies 275/65/20, i decided on still required a few hours on the driveway to remove the mudflaps (later i cut them and put them back on) and the front needed the spats removed and the liners had to be pushed forward.
    Had i not done any of that it would rub when the suspension flexed modestly and every time i reversed the truck. It gets old very quick so be aware, there will likely be additional work to make it right.
