Need slight front lift to level truck
Discussion in 'Suspension' started by trkr81, Jun 28, 2014.
  1. Jun 28, 2014 at 2:56 PM
    trkr81
    trkr81 [OP] New Member
    Hey guys (or gals),
    I'm looking for some input that will help me make the right suspension/tire choice for my Tundra. We just got a 2006 4x4 Limited. Stock tires are 265/65R17. I'd like to bump it up to 265/70R17 and level up the front 1" or 1.5" only. (Just enough to level it out --not interested in lifting this one).
    It's a daily driver and will rarely see off-road use. However, I may use to to pull a boat, small camper, etc so keeping the tire size close to stock will help with overall HP and fuel mileage when not loaded.
    I've found some cheap 1" "poly" spacers on ebay but I've read bad things about them and prefer steel or aluminum if possible. Also, is 1" enough to level it out, or do I need 1.5"?
    What do you recommend for leveling kits, and do you have any tire suggestions based on what I have described?
    Also, with only 1.5, do you think I need to drop the front diff and clap the CV's? Is that really necessary with such a slight mod?
    Thanks so much.
  2. Jun 28, 2014 at 4:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Not sure about the 06 but check out Toyteclifts.com for options.
    ODSteve likes this.
  3. Jun 28, 2014 at 9:33 PM
    ODSteve
    ODSteve New Member
    Steven
    2012 Thundra SR5 TRD CrewMax
    K&N Filter, Low Profile tool box.
    X2
  4. Jun 29, 2014 at 7:12 PM
    Livin-n-God's Country
    Livin-n-God's Country New Member
    Rick
    Park Falls, Wisconsin
    2010 Tundra SR5 Crewmax
    2.4"/1" Pro Comp Level Lift, LT275-70/18 BFG AT's
    I went with a Pro Comp and am very satisfied with it. I did 2.4 front and 1 rear, and a 1" taller tire same width (LT275/70R18). The lift came with the differential spacers so I would assume that if necessary the 1.5 would too.
  5. Jun 30, 2014 at 11:59 AM
    Welcome to the board!
  6. Jul 23, 2014 at 5:17 PM
    Chas of MRT
    Chas of MRT Banned
    Chas
    2006 Tundra
