Need Recommendations
Discussion in 'Tonneau Covers, Caps and Shells' started by badger2793, Jan 5, 2021.
  1. Jan 5, 2021 at 4:59 PM
    badger2793
    badger2793 [OP] New Member
    Utah
    2007 DC Off-Road Slate
    Just recently snagged myself an '07 DC and really want a topper. I want something not necessarily to sleep in, but to take camping. Just as important, though, is keeping things dry. I grew up in the rainy PNW and know how hard it can be even with a topper. I'm torn between the big 3: ARE, Leer, and SnugTop. Really not sure which brand to go with nor how to narrow things down. I appreciate any and all advice. Thanks!
  2. Jan 5, 2021 at 5:13 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    There honestly doesn't seem to be that much of a difference between the 3 from what I've seen. They can all be ordered with pretty much the same options. Snugtop's fold up front window is nice but more valuable if you have a CM with the full roll down rear window. You can get a removable front window if you're concerned about being able to clean the rear window of the truck or a sliding rear window if you just want to pass small stuff through from the cab.
    I'm in a Leer primarily because it was the cheapest option from the dealers around here. It's completely dry inside when it rains; the only time I get water inside is when I power wash it and only around the rear windows.
  3. Jan 5, 2021 at 5:23 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I agree,I think they are more alike than different really.
    Geography alone might be the deciding factor as the closest would have to be the cheapest I would hope?
    I have had decent success buying used really,even for a Longbed Tundra which has got to be a fairly rarely seen model.
    Cpl_Punishment likes this.
