Need Recommendations for Wheels / Tires
Discussion in 'Wheels & Tires' started by AgentOfWrath, Apr 18, 2018.
  1. Apr 18, 2018 at 6:51 PM
    AgentOfWrath
    AgentOfWrath [OP] New Member
    Tampa Florida
    2015 Tundra Crewmax 4X4
    Flowmasters | 4 Inch Lift | Linex | Diamonback HD Cover | 40 Inch LED Light Bar \ Rock Lights
    2015 4x4 Crewmax with a 3.5 inch lift and fender flares ( im preparing for new tires/rims )
    I know I want BF Goodrich KO2s and i dont want the tires to stick out past the fender flares.
    Ive been looking at 18x9 with a 25 mm offset. Im not sure if I want 20 inch and dont know what would look better.
    I dont think I want 12 inch rims.
    I want a beefy stance but not crazy. I dont want to cut anything either.
    Ideas / Suggestions ?
  2. Apr 18, 2018 at 7:45 PM
    Get with customwheeloffsets.com
  3. Apr 19, 2018 at 11:42 AM
    parpales
    parpales New Member
    Robert
    2012 Silver Tundra SR5 TRD
    ARE camper with led ligths,bed rug, bull bar with 216w led light in front.
    I will go with black rhino barstow 9.5x20 ofset +12 , nitto 33x12.5x20 ridge grappler and bilstein 5100 to level. Thts going next wk. on my 2012 Screenshot_2018-04-12-10-18-24.jpg
  4. Apr 19, 2018 at 3:18 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Bryan, 18x9 +25 mm is a good start. I would stay under 35" tire . 295/70/18 is a very popular size. You could look at a +18 to +12 if you want a little more aggressive stance. The 18" wheel vs 20 gets my vote. I like more tire vs wheel. As far as any modifications maybe some slight rubbing , nothing major. Post pics when you can :thumbsup:
  5. Apr 23, 2018 at 3:39 PM
    Tundra Tough
    Tundra Tough New Member
    2025 MGM Tundra Platinum iForcemax 4x4
    Ceramic Coated & PPF on Windshield and entire Front
    I put on a set of 285/55/20 KO2 D rated, after 10 miles back to the Dealership and had them removed, MPG dropped 1.5-2mpg, Dry grip worse than the Stock Bridgestone and the ride was stiffer. Interestingly the 275/55/20 is the correct size, they used the 285 which was $90 per tire more.
    AgentOfWrath[OP] likes this.
