Need recommendations for rear lift
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundrafan23, Sep 29, 2020.
  1. Sep 29, 2020 at 10:01 PM
    Tundrafan23
    Tundrafan23 [OP] New Member
    I have a 2020 Tundra and recently installed Toytec 2.5 Aluma coilovers and 2.0 Aluma rear shocks with coachbuilder +3 shackles. The problem is I run a cap on the bed of my truck and the coachbuilder shackles only gave me about 1 inch of lift instead of the 1.75 inches because of the weight of the cap. I am looking to add another 1-1.5 inches of lift in the rear. Should I add a 1 inch block or an add a leaf? I am leaning towards an add a leaf because I have heard some people complaining of vibration with the blocks. Anybody run an add a leaf and a shackle or a block and a shackle together? What are your thoughts?
  2. Sep 29, 2020 at 10:52 PM
    Zero One Actual
    Firestone air bags and a wireless compressor is what I did and I love it.
    I would suggest you do not do a block. A lot of others will as well.
    You can give Icon vehicle dynamics a call about their add a leaf setup that is adjustable as well.
    Tundrafan23[OP] likes this.
  3. Sep 30, 2020 at 7:13 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    An add a leaf. or a spring pack if a grand +-doesn't bug you. I also have a shell on mine and the CB3 shackles. Blocks can contribute to spring axle wrap which makes the pinion tilt up and down more on softer springs. ( higher and lower pinion angles can cause vibrations)The shackles leveled mine but after towing a few times with a load in the bed they have sagged and as soon as the rear of the truck sits lower than the front the steering gets weird. also since the weight is taken off the front the ride gets harder. I prefer an inch to 2 inches of Rake.
    Also airbags help a ton with towing.
  4. Sep 30, 2020 at 7:28 AM
    AZ_Tundra1
    AZ_Tundra1 Gold member
    Phoenix, AZ
    2020 White Tundra SR5
    Bilstien 6112 front shocks set at 1.9"
    Depending on where you are, valley spring shop in Phoenix gave me a $600 quote to rebuild my current spring pack with 3 more leafs. Cheaper than a new spring pack and a higher payload in the leafs and about 1.5" of lift.
    Tundrafan23[OP] and Black Wolf like this.
  5. Sep 30, 2020 at 7:35 AM
  6. Sep 30, 2020 at 9:21 AM
    aggiec05
    aggiec05 New Member
    Kyle
    airbags don't solve the issue properly, add a leaf or a new spring pack for the best ride and to level out what you will put in the cap and bed.
    Tundrafan23[OP] and HulkSmurf14 like this.
  7. Sep 30, 2020 at 10:27 AM
    Zero One Actual
    How to air bags not solve the issue properly? Thousands of truckers are doing it wrong somehow for years and never informed? Please explain?
  8. Sep 30, 2020 at 11:32 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Hopefully this doesn't throw a monkey wrench into the thread, But I use it all! I have Air bags, Shackles, blocks and a add a leaf! And have zero issues, Lol
    Sean492 likes this.
  9. Sep 30, 2020 at 11:35 AM
    And I would Definitely use Datstar cradles so you don't destroy the bags if the truck is on a lift being worked on.........it takes the stress off of the bags.
  10. Oct 26, 2020 at 10:52 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
