Need Power Folding Tow Mirrors
Discussion in 'Towing & Hauling' started by PlatPro, Jan 18, 2017.
  1. Jan 18, 2017 at 11:30 AM
    PlatPro
    PlatPro [OP] New Member
    Randall
    A silk gloved hand with brass knuckles underneath.
    2014 Platinum, TRD Pro Suspension , Truxedo Bed Cover, Vent Shade Rain Guards, Tint match windows,TRD Exhaust, Linex, Custom Dyno Tune, TRD SwayBar, and just started.
    Hey guys, I have a 2014 Tundra Platinum. It comes stock with the power fold small girly mirrors. I need tow mirrors for my truck but I need them have the power fold in order to get in and out of the garage. Oh and all the goodies; power heat, tinted glass, running light when the headlights are on and turn indicator.
    Also I have the "blind spot monitor" in my truck. I need a wiring schematic as to tie in an LED so I have that as well. I have searched and came up dry. You all have nailed what I needed before so no better place for me to ask for links and information.
  2. Jan 18, 2017 at 11:39 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Last time I read about Power Fold Tow Mirrors for Tundras',they were $3-400.... EACH!:facepalm::devil: Sparks Toyota is a good plce to start.I've bought a couple pairs of regular OEM Tow Mirrors from them.
  3. Jan 18, 2017 at 11:40 AM
  4. Jan 18, 2017 at 11:44 AM
    PlatPro
    Randall
    Our local dealer said, " No such thing. I will look in the aftermarket". Is that true? Not true?
  5. Jan 18, 2017 at 11:44 AM
    GNTundra and Y0TA PR0 like this.
  6. Jan 18, 2017 at 12:38 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Just make sure you order based on whether you have the memory function. They are not the same.
  7. Jan 18, 2017 at 2:32 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    CM-LENNY and Roman like this.
  8. Jan 18, 2017 at 2:35 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  9. Jan 18, 2017 at 2:49 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Roman and NewImprovedRon like this.
  10. Jan 19, 2017 at 4:51 AM
    PlatPro
    Randall
    You guys are awesome ! Thank you very much. Order is going in today. How is the best way to wire in an LED for my blind spot monitoring that my truck currently has?
  11. Jan 19, 2017 at 5:48 AM
    His link was not power folding, memory, or auto dimming.
    Need to compare apples to apples. :thumbsup:
    PlatPro[OP] likes this.
  12. Jan 19, 2017 at 1:18 PM
    Roman
    Roman
    Franklin, TN
    They are power folding. The only two options for the OEM tow mirrors are power folding or non-power folding.
    ColoradoTJ likes this.
  13. Jan 19, 2017 at 1:34 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Are there ones that come with all of those options OP listed?
  14. Jan 19, 2017 at 6:12 PM
    Well in that case, those are a great price.
    Roman[QUOTED] likes this.
  15. Jan 20, 2017 at 5:57 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    But it states "without auto dimming, without memory" - I was under the impression there were tow mirrors with at least memory...
  16. Jan 20, 2017 at 9:21 AM
    Roman
    Roman
    Franklin, TN
    That is correct. Toyota does not make the tow mirrors with memory nor auto dimming.
  17. Jan 20, 2017 at 9:25 AM
    SOB
    SOB Big Member
    Ohio
    I would think if the top mirrors power adjust then the memory would also work? Am I misunderstanding what the memory feature is? I thought it was the adjustable presets for seat/steering wheel/mirror position.
  18. Jan 20, 2017 at 9:30 AM
    Roman
    Roman
    Franklin, TN
    That's correct. If the mirrors are moved from their position, they will not automatically move back to the preset. You will have to move the mirror using the switch. No memory on tow mirrors.
  19. Jan 20, 2017 at 9:51 AM
    SOB
    SOB Big Member
    Ohio
    Interesting...thanks for the clarification.
  20. Jan 28, 2017 at 7:15 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
  21. Jan 28, 2017 at 7:33 AM
    lehminh
    lehminh New Member
    Oops! Sorry these are not power folding! Description confused me. Please delete my previous post.
  22. Nov 29, 2017 at 10:56 PM
    timebak
    timebak New Member
    2011 Black Tundra Limited
    Husky Mats, Trailer brake controller, Tonneau cover, other goodies coming soon.
    Roman, I ordered a set of these for my 2011 Tundra CrewMax Limited from you at Cool Springs Toyota. They came in yesterday and I installed them last night, but the clearance lights don't work at all and the turn signals are way too dim. Can you get me a wiring diagram for the mirrors that I bought that includes the pin functions for the female connector on the mirror? I'll also need a pin function diagram for the male half of the connector that's part of the truck.
    Thanks,
  23. Nov 30, 2017 at 7:43 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I did not know tundra offered power folding tow mirrors.
  24. Nov 30, 2017 at 3:36 PM
    Roman
    Roman
    Franklin, TN
    I can get you a picture of the connector, but you'd have to talk with your service department to get pin out information from the EWD.
  25. Dec 1, 2017 at 3:51 PM
    slhayes10
    slhayes10 New Member
    I am getting ready to order mirrors from Roman @ Cool Springs Toyota.
    Just confirming the following:
    Power folding tow mirrors
    https://stores.revolutionparts.com/...ota-mirror-879400c281/?c=aT04MTkyNzQ1NSZyPTE=
    https://stores.revolutionparts.com/...ota-mirror-879100c281/?c=aT04MTkyNzQ1NSZyPTE=
    The above mirrors will function with my 2008 Toyota Tundra Limited with memory and factory power folding sport mirrors. I understand that the memory function (i.e. buttons 1 and 2) will NOT remember mirror positions. But the power mirror, power fold, defrost, and turn signals will all function correctly?
    -Steve
    Roman likes this.
  26. Dec 4, 2017 at 3:05 PM
    Roman
    Roman
    Franklin, TN
    Correct. Everything will work except for the memory function.
  27. Jan 29, 2018 at 6:47 PM
    Sigbrown1297
    Sigbrown1297 New Member
    2018 Tundra Platinum
    Roman, I have a 18 Platinum. Interested in power folding tow mirrors. Is there OEM option? What feature will be lost?
    My understanding is the auto dim, memory set, puddle light, and BSM.
    Anything else?
    As long as the marker lights, power fold, Defrost, and turn signals work, I am ok with it.
  28. Jan 29, 2018 at 8:01 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    The side marker lights on the mirror won't work either, as the platinum isn't wired for them, but the blinkers will work.
    Sigbrown1297[QUOTED] likes this.
  29. Jan 29, 2018 at 8:41 PM
    Sigbrown1297
    There’s gotta be a way to tie in the marker light to the daytime running light to make them work
  30. Jan 30, 2018 at 4:39 AM
    Sigbrown1297
    What Mirrors are those?
    Tarzan and (deleted member) like this.
