Need new suspension?!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by LAenforcer, May 11, 2025 at 7:26 AM.
  1. May 11, 2025 at 7:26 AM
    LAenforcer
    LAenforcer [OP] New Member
    First, Happy Mother's Day to all the moms out there.
    Need some suggestions from you folks. I've got a 2017 TRD PRO with the Bilstein PRO suspension. It will probably need to be replaced soon. I love the soft, floaty ride. Looking for a good replacement with the same characteristics and stock ride height. Thanks!
  2. May 11, 2025 at 7:31 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Unfortunatley, I don't believe the Bilstein's are rebuildable. So, try to find a used set off a Pro w/the fox set up, and then have them rebuilt prior to install (usually about $150-$200 a corner), and you'll be happy w/the ride.
    If you can find a set near you, consider Kings or maybe the check w/guys running the eibachs and see how they compare...
  3. May 11, 2025 at 7:40 AM
    @memario1214 can help you out with that.
    memario1214 likes this.
  4. May 12, 2025 at 2:52 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    That's definitely doable! If you want a floatier ride I would probably consider something like the Eibach 2R setup. If you get down in the weeds what you have now is essentially a custom valved 6112/5160 setup that has probably stopped providing much in the way of compression/rebound. Have you had your truck since new?
    RobertD likes this.
  5. May 12, 2025 at 5:44 PM
    LAenforcer
    Yes, approaching 80k on it. I don't mind paying for quality. How much does that Eibach setup run? Bolt on replacement or is modification required?
