Need more rear lift
Discussion in 'Suspension' started by TritonDriver, Oct 18, 2020.
  1. Oct 18, 2020 at 3:44 PM
    TritonDriver
    TritonDriver [OP] New Member
    Georgia
    2020 Crewmax 4x4
    I recently had a RC 6” lift installed with Vertex C/Os.
    This kit lifts the rear with 4” blocks which keeps everything level but appears to have a slight sag to it. The sagging is really evident when towing my boat. I would like to get another 2-3” in the rear to have a slight rake. I have looked at the 3+ Coachbuilder shackles (1.75”) and the OME Dakar springs (2.5”). Would you guys recommend either of these options or something else? Also would these options work with the 4” blocks?
  2. Oct 18, 2020 at 3:54 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Have you considered airbags?
    Can't help ya with the spring/shackle combo.
    TritonDriver[OP] likes this.
  3. Oct 18, 2020 at 4:42 PM
    timsp8
    NY
    Depends on how much you want to spend. Less $ go for the shackles. More $$ go for the new springs. If it doesn’t matter, I’d go for the springs since factory ones are soft and start to sag after awhile.
  4. Oct 18, 2020 at 7:53 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
  5. Oct 19, 2020 at 5:46 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I just ordered a custom leaf pack from Alcan Springs. It will eliminate my 4" block. I also had them build it for 450lbs constant load. Cost me about a grand.
    SC_TRD, TritonDriver[OP] and DIYDad like this.
  6. Oct 19, 2020 at 6:20 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    What about lowering the front coils. Saves you some coin.
  7. Oct 19, 2020 at 8:23 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Eliminating the block sounds like a win to me. Be sure and come back and post your impressions once you've installed.
  8. Oct 19, 2020 at 2:01 PM
    TritonDriver
    Georgia
    2020 Crewmax 4x4
    Looks like springs may be the way to go. Thanks
    Only place where $500 an inch makes sense. Lol
  9. Oct 19, 2020 at 2:51 PM
    I have airbags on mine for towing and am very happy I did. Oh and your truck looks good!
  10. Oct 20, 2020 at 7:38 PM
    TritonDriver
    Georgia
    2020 Crewmax 4x4
    Thank you
