Need LED rear turn signal bulb without adding a resistor.
Discussion in '2.5 Gen Tundras (2014-2021)' started by westmsm93, Oct 27, 2020.
  1. Oct 27, 2020 at 3:59 PM
    westmsm93
    westmsm93 [OP] New Member
    Hello all,
    I am currently in the market for some sweet LED rear turn signal upgrade. I know it is the 921 blub. However I cannot find any info if I need a resistor or not. I prefer not to splice into the wiring as my wires are already fairly exposed. I see many generic LED 921 bulbs on Amazon and I am not sure if it will cause hyper flashing. Has anyone here upgraded their rear turn signal? What brand did you use and does it have a built in resistor?
  2. Oct 27, 2020 at 4:08 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    I used @Headlight Revolution for all of my LED upgrades. And yes their turn signals use a resistor that comes with the bulbs.
  3. Oct 27, 2020 at 4:17 PM
    westmsm93
    Nice! Can you do me a solid and find either the link or part number? I just looked at their website and there is a shit ton of them. Many don't include the resistor which is weird.
  4. Oct 27, 2020 at 4:28 PM
    NCTundra18
    Jeff
    Candler, NC
    Dang, they've changed their website since i got mine. But i have the GTR ones but i couldn't even find them. Maybe they'll chime in since i tagged them. Sorry i couldn't help.
    westmsm93[OP] likes this.
  5. Oct 27, 2020 at 4:31 PM
    You will have to wire in a resistor. Vleds is working on a Triton system for them but it will be a couple of months. I spoke to them yesterday. They are also testing and designing another product that will be pretty sweet once done.
    Black Wolf likes this.
  6. Oct 27, 2020 at 4:33 PM
    grichg
    grichg New Member
    rich
    Jumpers LED has good LED lights: csjumper2003@yahoo.com
    Hes on Tacoma Forum but not here. Send email with what bulbs you want and he will respond with options and pricing. Have bought many from him and great CS.
  7. Oct 27, 2020 at 5:58 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Just tap in a resistor. Nothing needs to be cut. Use electrical tape pulled tight and wire loom and moisture will never be an issue.
  8. Oct 27, 2020 at 6:00 PM
    Heat shrink works well too.
  9. Oct 27, 2020 at 6:27 PM
    Danman34
    Danman34 New Member
    Danny
    Heat shrink won’t work when you’re just cutting back insulation to solder in the resistor wire and you’re not actually cutting the main wire. Unless you pull the pins out the connector and can manage to slip a piece over the end of it to slide over the solder connection.
