Need HVAC input
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2018Tundra1794, Jan 24, 2019.
  1. Jan 24, 2019 at 8:55 AM
    2018Tundra1794
    2018Tundra1794 [OP] New Member
    Greg
    2018 Tundra 1794
    None
    Looking for others that have problems with the 3rd Gen automatic HVAC. My 2018 has a mind of it's own. You cannot control the temp and the system does not regulate the air temp coming out of the vents. One example: when set on defrost and feet mode at 70 degrees, the air temp coming out the vent climbs to 125 degrees and after an hour of driving it might drop to 110 degrees. Similar problem when you dial down the temp to 60 degrees. The temperature of the air coming out of the vents dropped to 43 degrees. The outside ambient temperature was 46 degrees.
    Thanks, Greg
  2. Jan 24, 2019 at 11:38 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Have you taken it in to have it checked out by the dealer for warranty work?
  3. Jan 24, 2019 at 12:07 PM
    2018Tundra1794
    Greg
    2018 Tundra 1794
    None
    No, however, I have discussed the issue with the service writer at my local dealer and he looked at me like I had two heads. I'm doing as much research as I can before I drop it off. I think this is a problem that many people have but have not blogged about. I'm trying to see if anyone else has noticed this problem. When I brought this issue up with my son (2016 1794) he said he has an issue but hasn't done anything about it. Dealers aren't into troubleshooting and this is a problem that will require much troubleshooting, so I am doing as much fact finding as I can before I start beating them up.
  4. Jan 24, 2019 at 12:34 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Research is good. Sounds like you've got a good plan. I fortunately don't have this problem.
  5. Jan 24, 2019 at 12:40 PM
    2018Tundra1794
    Greg
    2018 Tundra 1794
    None
    Do you have Automatic HVAC controls?
