Need help
Discussion in 'Suspension' started by Jl platinum, Dec 11, 2018.
  1. Dec 11, 2018 at 11:24 PM
    Jl platinum
    Jl platinum [OP] New Member
    2013 toyota sequioa platinum
    Corsa exhaust, bullydog tunner and intake , jl audio sound system and led intieror lights with spider head lights...
    I don't have a tundra but I do have a sequioa with rear air need help on any tips to change out rear suspension any help would be greatly appreciated
  2. Dec 12, 2018 at 3:31 AM
    BIGUGLY
    Paul
    2018 Limited
    Be very careful on the passenger side . Removing the shock can mess up the rear air coolant line pretty easy.
    When I did it to an old Sequoia we clamped the top of the shock and literally twisted the shock apart to since it was rusted so bad you could not get the nut off the top of the shock. This took awhile and a lot of cussing. But it was two big guys using a lift and a breaker bar for torque on the lower half of the shock.
    You could try a torch but we felt it was too easy to mess up the coolant line with it.
    Jl platinum[OP] likes this.
