Need help with this problem
Discussion in 'General Tundra Discussion' started by Tek, Apr 22, 2020.
  1. Apr 22, 2020 at 6:47 PM
    Tek
    Tek [OP] New Member
    Chu
    06 tundra
    question 1. I got a code of p0051 1 and 2. I couldn’t figure it out which side of oxygen sensor are need to change.
    question 2. Need to change this one what kinda part I need. CB66BFB7-09C7-416C-92DA-3BC9EA1D0B8D.jpg
  2. Apr 22, 2020 at 7:08 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    A P0051 DTC trouble code refers to the O2 sensor (oxygen sensor) located on Bank 2 in front of the catalytic converter. There is also an oxygen sensor behind the converter which is Sensor #2. ... This O2 sensor #1 may also be refered to as an air/fuel ratio sensor since on some vehicles it is.
    Here's one for a 2010 5.7, https://www.amazon.com/Bosch-15974-...33------------&vehicleName=2010+Toyota+Tundra
    Part 2 looks like a link. I'd show that to Roman...
    Tek[OP], TILLY and Y0TA PR0 like this.
  3. Apr 22, 2020 at 7:35 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Looks like a front sway bar end link
    Tek[OP] and TILLY like this.
  4. Apr 22, 2020 at 7:38 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  5. Apr 22, 2020 at 7:41 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!
