Need Help with Power Loss
Discussion in '2nd Gen Tundras (2007-2013)' started by jtg1441, Apr 5, 2023.
  1. Apr 5, 2023 at 6:17 PM
    jtg1441
    jtg1441 [OP] New Member
    07 Tundra 4.7I
    New to Toyota. I recently purchased a 2008 Tundra 4.7I. After driving the truck for a few weeks, my VSC flashing and trac control & check engine light came on and a significant loss of acceleration power. OBD2 shows Code P0419 SAIS Relay "B" Circuit. The fix finder report Autozone printed out after the OBD2 reading says to replace Air Injection Pump & Diverter Valve. My question is would a SAIS Bypass kit fix the problem permanently or should I replace with OEM parts.
  2. Apr 5, 2023 at 7:51 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    There is 2 ways to go about it, if your state doesn't require a vehicle inspection. You can either look up the SAIS bypass on this site and self-educate on it, which is considerably cheaper than replacing OEM parts and effective. #2 replace with aftermarket and/or OEM parts, which may be more expensive, but necessary if you require an inspection.
    It will fix the problem permanently, until it requires to be replaced again, for OEM/aftermarket replacement parts.
  3. Apr 6, 2023 at 6:44 AM
    jtg1441
    07 Tundra 4.7I
    Ok thank you.
