Need help with a leveling kit
Discussion in 'Suspension' started by onetohunt, Aug 24, 2017.
  1. Aug 24, 2017 at 6:58 PM
    onetohunt
    onetohunt [OP] New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    New to this lift/leveling scene. I would like to know which is the best route to take for a leveling kit. I would like to level it out without breaking the bank. Problem is I have no clue. I'm not a big off roader in the truck, I have other toys for that. What I would like to do is keep or make the ride a little better. My truck is more of a pavement queen and will hit a field or two every now and then. It will tow my Can Am and that is about it. What I would like to know is what kind of kit will fit my needs. I'm thinking something either a 3-2 or 3-1? I'm just not sure, what I'm needing as far as what kind of leveling kit to get (brand wise?). The ride is my main thing, plus the way the truck will set is the next thing. thanks for any info.
    ColoradoTJ likes this.
  2. Aug 24, 2017 at 7:02 PM
    If you don't want to break the bank, and want a good ride, might want to stay away from spacer lifts.
    Look into Bilstein 5100 series shocks or 6112's. I was very pleased with my 6112/5160 shock setup.
  3. Aug 24, 2017 at 7:06 PM
    laniermax
    laniermax New Member
    Jack
    Atlanta
    2014 Tundra Limited 4x4 DC TRD Off-Road, Sunset Bronze
    Retrax Pro, AMP Bed Step, Aries 3D Mats, Thule Roof Rack, Bilstein 5100's, SCS SR8 Wheels, Toyo AT2's.
    +1 on the Bilstein 5100's. I went with the front height adjustable shocks because I was just looking to level the truck all around and upgrade to 33" tires. I'm very happy with the setup!
    duece292 and SouthBoundSteve like this.
  4. Aug 24, 2017 at 7:12 PM
    onetohunt
    Marvin
    Thanks for the responses already. Question though, if I go with the Bilsteins up front, what do I need to do on the back end? thanks.
  5. Aug 24, 2017 at 7:14 PM
    If you do a 3/1, you can run a Bilstein 5100 or 5160
    SouthBoundSteve likes this.
  6. Aug 24, 2017 at 7:58 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I have 5100's on all four corners. The fronts are on the middle setting which netted me 1.7 inches. The rear is at stock height. All around the ride is excellent. The truck "looks" level but still has a slight rake to it but the rake keeps it level when I'm pulling my boat. I think at the top setting you'd gain about 2.5" and at the top most add a 1" block to the rear.
  7. Aug 25, 2017 at 5:07 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Without breaking the bank, like everybody else is saying billies are the ticket, although they only go up to 2.5" slap on some coachbuilder shims and you're good. Could spend a little more $$ and get either Old Man Emu or Toytec BOSS. All are good options.
    Good luck brother!
    duece292, T-Rex266 and NewImprovedRon like this.
  8. Aug 25, 2017 at 5:27 AM
    laniermax
    Jack
    Atlanta
    I have the TRD off-road package and decided to just keep the stock Bilsteins in the back. In the front, I went with the middle setting on the 5100's to get a nice level look all around.
    duece292 likes this.
  9. Oct 30, 2017 at 12:12 PM
    SC_HANK
    SC_HANK New Member
    2016 Tundra TRD Off-road
    @laniermax do you have a pic you can share?
  10. Oct 30, 2017 at 12:16 PM
    STAY AWAY FROM ROUGH COUNTRY!!!!!!
    T-Rex266, 4x4_Angel and SC_HANK like this.
  11. Oct 30, 2017 at 12:22 PM
    SC_HANK
    SC_HANK New Member
    Spacers or 5100's? My local shop does not have great things to say about Bilstein in general but that does not really mean much to me frankly... Spend most of my time on pavement- I want to level the truck without sacrificing ride quality... 2016 TRD Off-road CM. I would love to go BOSS but with new tires and install that adds up to more than I want to spend right now... any suggestions would be helpful
  12. Oct 30, 2017 at 12:29 PM
    Stay away from spacer lift IMO
    SC_HANK[QUOTED] likes this.
  13. Oct 30, 2017 at 5:52 PM
    Blindman75
    Blindman75 New Member
    I was looking at the rough country spacer lift for my 08 2wd. It's a highway queen and just wanted the leveled look. Just curious why to stay away?
  14. Oct 30, 2017 at 5:58 PM
    Crap components i have a 6" lift came into lifted scene blind lots people i talk too round my area say rc is trash i wanted to lower my truck until i found out my rear crossmembers are cut out for this kit so I'm stuck with it now I'm hearing all kinds of creaking noises from front i hate it
    Blindman75[QUOTED] likes this.
