Need help.. suspension
Discussion in 'Suspension' started by Jac_htx, May 25, 2025.
  1. May 25, 2025 at 3:14 PM
    Jac_htx
    Jac_htx [OP] New Member
    2017 magnetic grey sr5
    Hi guys my cousin is looking to get a RC lift on his 2015 CM 2wd.
    RC website states that 2wd and 4wd are different suspension is that true?
    also wondering if all 14-21 front suspension is the same? We contacted RC and they said 14-15 front suspension is different from 16 and up.
    my 17 came lifted when I got it so I’m asking for him. Thanks
    (Also yes I know yall hate RC. Please don’t bash him) lol
  2. May 25, 2025 at 3:41 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    He needs to conduct his business with Colton at Hotshot Offroad. @memario1214 on here. Look him up. His # is in his sig line.
  3. May 25, 2025 at 3:52 PM
    RobertD
    Robert
    DFW, Texas
    As stated, I bet @memario1214 has a better product then RC for close to similar cost.
    But to answer your questions, 2wd and 4wd do have different front shocks part numbers due to 4wd having more weight up front. For shocks that are adjustable you get more lift on a 2wd than 4wd for above reason. But technically the parts can be "interchanged" since the mounting is identical. It will just vary the lift height if you swap between the 2.
    And all 2007-2021 use the same shocks.
    joseph_womack and Jac_htx[OP] like this.
  4. May 26, 2025 at 7:25 AM
    Jac_htx
    Thanks for the replies.
    so what you’re saying is if he gets a 4inch lifted strut for 4wd although he’s rwd it’ll give him more height?
    RobertD[QUOTED] likes this.
  5. May 26, 2025 at 7:29 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Correct. His UCAs and CV axles won't be the biggest fans of it, but that's exactly what will happen. From strictly a mounting perspective, it'll go as @RobertD has alluded to, but he'll get more height out of it.
    RobertD likes this.
  6. May 26, 2025 at 7:31 AM
    RobertD
    Robert
    DFW, Texas
    Depends how it gets the lift, but in general yes.
    I should have clarified that this is the case for preloaded coil lifts or lifts that use the coil (either longer or heavier) to achieve the advertised height. Since 4wd is heavier if you use front shocks expecting that much weight and put them on a 2wd, you will get more height.
    I guess this would not change if you are just adding spacers/blocks on top of the existing shock since you wouldn't be affecting the coilover compression. If that makes sense.
  7. May 26, 2025 at 7:34 AM
    memario1214
    Colton
    Missoula, MT
    Also, the reason that RC is stating that the 14-15 suspensions are different than 16+ is because Rough Country lifts that are 4"+ use different spindles. The spindle was changed for the 2016 model year so things get a little muddy.
    joseph_womack and RobertD like this.
  8. May 26, 2025 at 7:39 AM
    RobertD
    Robert
    DFW, Texas
    Ah! I didn't know this.
    Good info as always Colton
  9. May 26, 2025 at 7:44 AM
    Jac_htx
    Damn thanks guys for the help. I myself didn’t even know this.
    I guess he’s gonna go the 3.5 RC 4wd lift with lifted strut. I guess he’ll get 4inches lol
    now back to me. I’m on spacers 2inch front and 2 inch block back. I’m 2wd as well and don’t feel like breaking the bank but want a little bit higher lift. What you guys recommend? I don’t want RC lol
  10. May 26, 2025 at 7:45 AM
    RobertD
    Robert
    DFW, Texas
    Eibach Pro suspension from @memario1214
  11. May 26, 2025 at 8:08 AM
    memario1214
    Colton
    Missoula, MT
    My gut is the Eibach kit as well. Will be a little more supple than other offerings which should play nicer with the 2WD.
  12. May 26, 2025 at 8:29 AM
    Jac_htx
    Is there an option for 4inch? I think 6 is too much lol.
  13. May 26, 2025 at 9:08 AM
    memario1214
    Colton
    Missoula, MT
    There is... but it's not what you are going to want to hear. Going north of 3 inches isn't possible without replacing your spindles. There's far too much angle applied to both the CV axles as well as the UCAs to hang out there without stuff ripping apart. If you want 4 inches+, at a baseline you're going to need to replace spindles and other supporting components to make it happen.
    RobertD likes this.
  14. May 26, 2025 at 10:02 AM
    Jac_htx
    Does the UCA and and spindles not come with the kit?
  15. May 26, 2025 at 10:03 AM
    memario1214
    Colton
    Missoula, MT
    Rough Country 4" kits come with new spindles. They don't include UCAs though as the geometry there is largely unchanged, or at least within spec for stock arms.
  16. May 26, 2025 at 10:34 AM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    I think the spindle was changed for the 2016 model year so things get a little muddy.
