Need help replacing aftermarket foglights
Discussion in '2nd Gen Tundras (2007-2013)' started by Rozr1, May 15, 2021.
  1. May 15, 2021 at 2:48 PM
    Rozr1
    Rozr1 [OP] New Member
    2008 SR5 DC
    • So I was hoping to replace my non working foglights with a pair I just received this weekend. When I open up the fender cover I noticed the foglights are connected differently then what I've seen on YouTube videos and looks like it won't be exactly plug and play. As you can see on the pics the factory connector has been cut on the driver side and it's has more connectors running to different areas. Any idea what all this is and how should I go about replacing the foglights?
    Update, plugged in new foglight on passenger side and won't work, can't connect it on driver since connector is cut...
  2. May 15, 2021 at 4:14 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Did you verify the wires have power?
  3. May 15, 2021 at 6:04 PM
    Thats a hacked install. That is one of those cheap aftermarket HID kits that were everywhere for $50.00
  4. May 15, 2021 at 6:09 PM
    Thats a cheap aftermarket HID kit.
  5. May 15, 2021 at 6:36 PM
    Rozr1
    2008 SR5 DC
    Looks like the 15a fuse is blown for the foglights.... will go to autozone tomorrow for a replacement.
    I was guessing it was some hid foglights, can I just remove all that crap and just do a straight plug and play? Any idea how I can fix the driver side foglight connector that is cut, besides replacing the wiring harness?
    Also the hid foglights should not be wired to the headlights right? Will have to trace the hid foglight wiring tomorrow but it might be wired together. Previous owner put some old spyders headlights and not sure if they are wired together
  6. May 15, 2021 at 7:43 PM
    SouthWestGA
    SouthWestGA New Member
    Don’t feel bad
    My 07 had hack job HID kits when i got it
    I fixed the headlight portion of it but still have to fix the fog lights part of it.
    You're not the only person
