Need help removing front clip
Discussion in '1st Gen Tundras (2000-2006)' started by ChiefLang, Dec 18, 2017.
  1. Dec 18, 2017 at 9:50 AM
    ChiefLang
    ChiefLang [OP] New Member
    I am new to the forum.
    Looking for help removing the front clip.
    Have the outer fenders off and hood and bumper now how do we get inner fenders off.
    My son wrecked the car so we are fixing it ourselves.
    Need to get rest of front assembly off looks like radiator support comes off as one piece but with the wreck we are a little unsure.
    ChiefLang
  2. Dec 19, 2017 at 7:08 AM
    scruffy
    scruffy New Member
    Dmitriy
    2014 Toyota Tundra Double Cab Limited TRD 5.7 4X4
    The front core support is spot welded on. That said if replacing, the spot welds need drilled out with a special bit making sure to only drill through the first layer then ground flush after the support is removed. New core support will need welded on.
    allibubba and dcsleeper408 like this.
