Need Help! P0705
Discussion in '2.5 Gen Tundras (2014-2021)' started by eSkittles, Oct 20, 2022.
  1. Oct 20, 2022 at 12:21 PM
    eSkittles
    eSkittles [OP] New Member
    2021 Tundra Amy Green 1794
    Hello, I am in desperate need of help. I have search through multiple forum post with similar issues.
    This problem first occurred to me at around 6k miles. The dash lit up with CEL and a bunch of functions unavailable. (Pre-collision, cruise control, trailer brakes)
    I took it into a Toyota dealer and they recalibrated the shift sensor and told me not to rest my hand on the shift level. This fixed it...for now
    Fast Forward about 8k miles, the same problem came up and the Toyota dealership won't touch the truck because it is modded (it was modded at the first visit).
    The code only occurs 90% of the times, it fixes it self sometimes.
    Pre-collision, cruise control, trailer brakes do not work as a result from this. Additionally, I cannot manually shift gears when shift level is in 'S' mode. (gear numbers are not visible)
    I took it to a local shop that specialized in Toyota trucks and had them replace the Transmission Shift sensor. They took apart the center console shift area and found no issues.
    Some symptoms i have noticed:
    Truck is sluggish when taking off from first gear (feels like its in 2nd).
    I have Kings, Icon RXT 2nd option, and some lights wired to Switch Pros 9100.
    Any ideas would be greatly appreciated.
    Thanks
  2. Oct 21, 2022 at 9:45 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
  3. Oct 22, 2022 at 1:36 AM
    eSkittles
    I do not have aftermarket bulbs, I do however have some "add a circuit" fuse taps in the fuse box that are wired to my SP9100. Maybe thats it?
  4. Oct 22, 2022 at 1:43 AM
    Joe333x
    Joe333x Member
    Boston
    Worth disconnecting and ruling it out as a cause maybe? When in doubt, especially this new of a vehicle, remove all aftermarket stuff and see if the problem continues. Then you can always go to a dealer stock for them to take care of an issue thats not aftermarket related. As far as using add a circuit for power, you may want to consider using a relay that just uses an add a circuit type fuse as a trigger to draw directly from the battery. That way you are not drawing power from other circuits but only drawing power when the ignition is on. That's how I power my compressor.
    ColoradoTJ likes this.
  5. Oct 22, 2022 at 5:46 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I had that code when I first bought mine used. In my case the previous owner had the cam tower seals fixed under warranty and the dealer that did the work removed the cab. After having it back to the dealer I bought it twice, it was found that the other dealer must not have drained the lines to the heater core well before removing everything and coolant dripped into the electronic components and relays located in the passenger side kick panel. It corroded a bunch of stuff. They cleaned it all up and no issues since. That’s of course a very unique scenario though.
  6. Oct 30, 2022 at 3:07 AM
    eSkittles
    man i've heard so many things that causes this now lol
  7. Nov 1, 2022 at 10:23 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I had the same symptoms and code, checked my battery and it was bad. Got a new battery and everything cleared up.
    HulkSmurf14 likes this.
