Need Help finding what a part is called.
Discussion in '1st Gen Tundras (2000-2006)' started by C.Jones07, Jun 30, 2025 at 10:40 AM.
  1. Jun 30, 2025 at 10:40 AM
    C.Jones07
    C.Jones07 [OP] New Member
    Yesterday
    2002 Green Toyota Tundra RWD
    added a Subwoofer, aftermarket Radio, New Door speakers and Tweeters
    I have a 2002 Toyota Tundra RWD SR5. I replaced the radio but when I pulled out the Dash to do it the plastic holding the Hazard lights and clock electronics crumbled an fell apart. If any one know what the parts called or where to get a replacement please let me know. thank you
  2. Jun 30, 2025 at 10:44 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Control Bezel - Toyota (84013-0C010)
  3. Jun 30, 2025 at 10:45 AM
    badass03taco
    Trim Plate - Toyota (83911-0C020)
    Clock, 3.4L. Clock, 4.7L, with 2wd. 2wd, without trac switch.
  4. Jun 30, 2025 at 10:46 AM
    badass03taco
    Trim Plate - Toyota (83911-0C010)
    Clock, 4.7L, with 4wd.
  5. Jun 30, 2025 at 5:19 PM
    shifty` We call it “riding the gravy train”
    Give us a pic of what crumbled, and if that part doesn't look right, I'm happy to look it up.
    But just know, many of those parts in the center dash sub-assembly are discontinued. So would really help to see what you're dealing with.
    Sadly, the AC controls between years/models aren't interchangeable either, so you often can't just swap the center dash over from another truck.
    Make sure you're correctly installing the radio. Find out if you have an OEM amp in the dash, more info on your year is here. List of adapters here, so you don't need to be the stupidfuck who cuts the factory harness. If you're already aware of these two things, disregard.
