Need help diagnosing a strange sound
Discussion in '1st Gen Tundras (2000-2006)' started by Kimosabe, Apr 21, 2025.
  1. Apr 21, 2025 at 1:02 PM
    Kimosabe
    Kimosabe [OP] Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I’m having a strange noise while driving that I’m having trouble diagnosing. It’s been happening for almost a year. It was subtle at first but has gotten more pronounced in the last week.
    I thought it was driveshaft related but replacing carrier bearing didn’t help and I did not find any play in u-joints.
    The noise is a whomp, whomp sound which speeds up with acceleration. However, it stops when I apply the brakes. I suspected front wheel bearing, but can’t detect any play. I can hear/fell the vibration in the driver seat but I am not certain of the location. Recently, it sounds like it's coming from the rear more than in front of the driver seat.
    Any suggestion would be appreciated before I take it to a shop or start throwing parts at it.
  2. Apr 21, 2025 at 1:18 PM
    Whomp whomp sound
    Increases with RPM
    Stops with braking
    Could be a bad wheel bearing still. Could also be a stuck piston in the caliper, that’s rubbing until you tap the brakes.
    Have you checked the pads for uneven wear that could suggest one of the two pistons may be wearing uneven? You should be able to see the pad wear with the front wheel on and the wheels kicked full-lock left and right.
    bfunke likes this.
  3. Apr 21, 2025 at 2:11 PM
    Kimosabe
    Sun Valley, Idaho
    I haven't checked the front pads in a couple weeks, but I didn't notice any uneven wear on either side. The driver side wheel has more resistance than the passenger side when spinning with both wheels off the ground.
    I'm going to edit my post above, but I paid closer attention just now when driving to the office. It's hard to pinpoint where the sound is coming from, but now I'm thinking rear. I applied the parking brake 1 or 2 clicks and it went away. There is also a creaking sound when coming to a stop at 5-10 mph which is definitely in the rear. Is there a way to check rear wheel bearings for play? I don't have any gear oil leaking in the rear, and I'm going to check my rear brakes to make sure everything looks good there. I replaced shoes and wheel cylinders last July (2024), and rear diff fluid back in February of this year.
  4. Apr 21, 2025 at 3:08 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If it’s now from the back, I personally would jack the whole rear up and spin the wheels.
    Last resort to really tell, if one is being safe and cautious, chock front wheels good, jack up rear and put in drive.
    edit….just run across this thread from years back, same whomp whomp description….also, video posted NSFW :facepalm:
    https://www.tundras.com/threads/rear-wheel-annoying-sound.130138/
    FrenchToasty likes this.
  5. Apr 21, 2025 at 3:19 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Thats how I diagnosed my bad rear bearings, in the cinders, a little weird sitting still and seeing the speedo at 55
    BubbaW[QUOTED] likes this.
  6. Apr 21, 2025 at 3:33 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I found bad third member on first gen Tacoma by attaching GoPro with magnet to axle assy and record. This was after changing wheel bearings, PB blaster in carrier bearing, and moving tires around.
  7. Apr 21, 2025 at 3:34 PM
  8. Apr 21, 2025 at 3:45 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Kimosabe[OP] likes this.
  9. Apr 21, 2025 at 4:06 PM
    Holy crap, I can't believe I forgot about Brock. Sucks his truck got totalled not long after that in an accident. That guy was a hoot. Some folks were speculating he was our beloved handy model, but he doesn't look nor sound quite right.
  10. Apr 21, 2025 at 6:47 PM
    Kimosabe
    Sun Valley, Idaho
    After watching that video I’m suspecting more and more it might be a rear wheel bearing. Fuck stick! I’ll have to jack up the rear and try and confirm tomorrow. Thanks everyone for chiming in and I’ll try and confirm. I’d take a video but it might be hard to hear over the exhaust leak. Ugh!
    BubbaW likes this.
