Need Help Deciding
Discussion in 'Suspension' started by JBSTOY, Jan 9, 2017.
  1. Jan 9, 2017 at 9:00 PM
    JBSTOY
    JBSTOY [OP] Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    So I had my wheels full tilt today and I noticed the coil was grease covered at the shaft entrance of the front strut. It is a 2008 Tundra. I was going to throw a spacer in to bring the front end up, but now I'm thinking of going with the Bilstein 6112 and have it set at the highest level. Question has anyone else done this? How did the truck ride compared to stock? Did it level the truck? Anything I need to watch out for? Also, this is my tow vehicle and daily driver. Thanks in advance.
  2. Jan 9, 2017 at 9:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not me but plenty others here have put on 6112's. It will definitely be an improvement over stock. Lift it 2" and you should be level. But if you do a lot of towing, it's not a bad idea to have a little rake.
    JBSTOY[OP] likes this.
