Need help before I order… wheels related
Discussion in '3rd Gen Tundras (2022+)' started by 2000army, Oct 4, 2022.
  1. Oct 4, 2022 at 10:30 AM
    2000army
    2000army [OP] New Member
    CT
    Looking at these available in +1 and +20 offset ... Im assuming I want the +20? I have 295/70/18 Mickey Thompson Baja Boss AT tires coming in. No lift…yet. will possibly do the Westcott 3/1 or 3/2 in the immediate future. How much poke with each would you think… I prefer right up to the fender end and maybe slightly over but don’t want it to look idiotic
    Part# Model Finish Size Bolt Pattern BS Offset Bore Weight Load Lip Size Cap MSRP
    D68018908457 D680 REBEL MATTE GUN METAL 18X9 6X139.7 5.79 20mm 106.10 35.00 lbs 2300 0.90 1004-69GD $376.00
    D68018908450 D680 REBEL MATTE GUN METAL BLACK BEAD RING 18X9 6X139.7 5.04 01mm 106.10 36.00 lbs 2300 0.90 1004-69GD $376.00
  2. Oct 4, 2022 at 12:27 PM
    2000army
    CT
    Ordered the +20
  3. Oct 4, 2022 at 7:48 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    X2 on the +20
  4. Oct 4, 2022 at 7:53 PM
    BMP1980
    BMP1980 New Member
    2022 Tundra TRD Off Road
    None
    Not a reply about the wheels but I noticed you were thinking of going with the 3/1 or the 3/2. Maybe a weird question but which of these would level the truck?
    I am a new owner and thinking about leveling and wonder which is best. Thanks in advance for your reply.
  5. Oct 4, 2022 at 7:58 PM
    2000army
    CT
    It’s going to depend if I put the uptop rack on my Retrax or not
  6. Oct 4, 2022 at 8:32 PM
    murtro
    murtro Life is unpredictable. Eat dessert first!
    Alberta
    The OEM wheels are +50ish, if you go +20 then you will move the wheels out 3 CM or about an inch and a half.
    Stock tires are 265/60. 295/70 are about 5cm wider, which will add 2.5 CM outside.
    So total they should stick out 5.5 cm more than stock or about 2.25".
  7. Oct 4, 2022 at 8:35 PM
    murtro
    Alberta
    btw - I've seen these wheels in person and they look awesome - but you will have a little "poke".
  8. Oct 5, 2022 at 4:44 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Definitely 20 but you already knew that and bought them. I looked at those same rims, almost pulled the trigger but couldn’t bring myself to buy them because of the weight, plus the additional weight of the tires.
