Need HELP.... BDS LIFT
Discussion in 'Suspension' started by sargebt, May 16, 2019.
  1. May 16, 2019 at 2:31 PM
    sargebt
    sargebt [OP] New Member
    Brandon
    2016 Platinum Tundra
    7 inch BDS, running 35’s
    Does anyone have issues with their BDS suspension lifT? I have a 2016 platinum tundra with 30,000 miles. At slower speeds maybe 10 miles an hour to 20 miles an hour when I drive over brick pavers or small bumps I feel that there is something loose all most in the front end?? It doesn’t sound stable like a truck should. Could it be the sway bar? Heim joints? Highway speeds it drives like a dream
  2. May 16, 2019 at 2:41 PM
    I'd take it back to where the lift was done have them ride around with you, re torque everything down
  3. May 16, 2019 at 2:48 PM
    sargebt
    Brandon
    It’s been retorqued that’s the thing. Making me crazy
  4. May 16, 2019 at 2:52 PM
    Wow, maybe have someone walk with you drive slow they can pin point it or use a goPro ???? Or jack up and see what you can move by hand see what's loose, hope you can find it
  5. May 16, 2019 at 3:49 PM
    sargebt
    Brandon
    I’m going tomorrow morning. I just wanted to know if anyone else had any ideas
  6. May 16, 2019 at 4:00 PM
    Hope it gets resolved
  7. May 16, 2019 at 4:25 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    What issues are there?
  8. May 16, 2019 at 4:30 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    I haven’t heard of any issues, I want to put that lift on my Tundra.
  9. May 17, 2019 at 3:11 PM
    ManoTundra
    ManoTundra New Member
    T
    NorCal - NE Bay
    2018 MGM Limited CM
    I just had a 3" coilover BDS kit installed on mine, and it did the same thing to me as well. I had to drive over that speedbump several times but yeah I couldn't figure it out. Spare tire is rock solid with no shaking so not sure what it is. Had mine retorqued and they couldn't find anything but I havent been over that speedbump since then either. I'll have to try it again later. Going back to my install shop once I get back in town next week. If they find something, I'll let you know!
  10. May 17, 2019 at 3:56 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    My installer said no issues with tundra BDS, he is one of the best if not the best in my area. He’s an excellent fabricator, and has an excellent reputation and stands by his stuff. He recommend BDS over most brands.
    ManoTundra likes this.
  11. May 25, 2019 at 10:48 PM
    David923
    David923 New Member
    David
    AZ
    2010 Nautical Blue Tundra CrewMax
    KN Airfilter SCS SR8 Gunmetal
    I’m actually currently looking into BDS uca’s for my 2010 CM, anything I should know before pulling the trigger?
    I’m already skeptical of any brand just due to the horror stories I’ve heard and read of on the inter webs, not that any particular brand is problematic just want to do a one and done if possible.
  12. May 26, 2019 at 12:02 AM
    David923
    David923 New Member
    David
    AZ
    Agreed, absolutely the best for alignment purposes, and was on the road in purchasing them but a few concerns come to mind with them. 1) knowledgeable facility that understands how SPC adjusts for optimal performance and 2) a single bolt that secures the ball joint. (Would hope it wouldn’t come loose)
    Besides these concerns I’ve been gtg with them, which is why I started researching elsewhere.
    Thanks for your response
    15Yota likes this.
  13. May 31, 2019 at 7:58 PM
    ManoTundra
    T
    NorCal - NE Bay
    2018 MGM Limited CM
    So I finally got back in town and took my truck back to my installer, they had already retorqued but they did again and said nothing was loose. I couldn't find anything underneath loose either. It's been driving me crazy too lol it's so weird!
    Do you find anything?
  14. May 31, 2019 at 10:36 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Tie rod hitting the shock?
