Need help 4x4 binding
Discussion in 'New Member Introductions' started by Taco17, Dec 8, 2017.
  1. Dec 8, 2017 at 7:00 AM
    Taco17
    Taco17 [OP] New Member
    JULIO
    2017 Tacoma TRD sport 4x4
    HI i just got my new 2017 4x4 , I dont know anything about 4x4 so i wanted to test it and I did it on DRY pavement , I know now that is a NO NO but i am worrie that i broke something basically i but the truck in 4x4 in the parking lot and i started driving didn't really feel anything other that tractcion from the front but when i got to my destinistion about less than a mile away in the parking lot when i was truning my wheels started to lock on me to the point the car didn't move i really didnt but any gas or pushed it i simply but the wheels straight and took the truck from 4x4 to 4X2 the light on the dash " little car with 4 wheels " was flashing like if it was trying to disengage so i press on the gas just a bit the cars start moving and i hear a pop the light is now off and i am in 4x2 mode if i try to activate the 4x4 i hear a little sound like something is engaging and the light appers i did several times just to check if something was wrong it apears to be working fine but i couldn't sleep last night just thinking about that stupid mistake i made. I know i can't use 4x4 on pavement i am well aware of that now but do anyone think that something broke by this happening once?
  2. Dec 8, 2017 at 7:04 AM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    Delete this quick. Apply warranty. It just started not working followed by repeating the phrase huh.
  3. Dec 8, 2017 at 7:21 AM
    Welcome from CO
    Traction light goes on (which is the dahs light you described) when 4WD is engaged. You can drive it in 4WD (10 miles per month is recommended) but it has to be on straight pavement. Don’t turn while engaged in 4WD on dry pavement or youll bind the driveshaft like you did here. I’m sure it’s fine.
    Backslider and NewImprovedRon like this.
  4. Dec 8, 2017 at 7:51 AM
    Taco17
    JULIO
    Great the cars has 80 miles only i feel so bad !!! so just to be clear the bind is normal but since this only happened once it should be ok and its design to take it ? it just really bothers me that it popped.
  5. Dec 8, 2017 at 7:52 AM
    If you turned on dry pavement in 4WD the bind is normal.
    The sound you heard is prob the driveshaft engaging in/out of 4WD
    15whtrd likes this.
  6. Dec 8, 2017 at 7:53 AM
    Taco17
    JULIO
    I am more confused than when i started, i don't understand what you are trying to tell me " NO offense "
  7. Dec 8, 2017 at 7:57 AM
    Taco17
    JULIO
    i hope !!! I did went under the car and did a visual inspection I didn't see anything broken or out of place
  8. Dec 8, 2017 at 7:59 AM
    Taco17
    JULIO
    Well thanks for the help i hope this help other people to understand, i can sleep tonight !! lol
  9. Dec 8, 2017 at 8:04 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome.
    Bienvenido
  10. Dec 8, 2017 at 8:06 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    I'm saying if you messed up your truck due to driver error and not reading the manual and have to get it fixed I would get rid of the post stating how you messed it up so there isn't an issue with getting the warranty to cover it. For example proof online that you messed it up. I'm sure you will be fine and hopefully everything is okay. Sean266 is very knowledgeable. Sorry for the added confusion in your time of crisis.
    NewImprovedRon and Y0TA PR0 like this.
  11. Dec 8, 2017 at 8:12 AM
    Taco17
    JULIO
    I got you now , thanks !!
    NewImprovedRon likes this.
  12. Dec 8, 2017 at 8:18 AM
    Welcome from Texas! Hope it working all fine
    Taco17[OP] likes this.
  13. Dec 8, 2017 at 8:18 AM
    Welcome from Ohio!!
  14. Dec 8, 2017 at 8:23 AM
    BakNBlk2014
    Donald
    Virginia Beach VA
    Just Google searched the binding issue and got a lot of good info and insight into how why and when this binding happens and what the noises are that you heard. Also pulled up a thread from this site a couple years old in binding and best ways to engage disengage 4x4 hi on dry pavement to lube up. Don't turn, disengage while moving before turning. Engage while in gear moving to help with line up etc. I've had my truck since Feb and about 4k miles on top of the 25k it had and need to do this.
    Taco17[QUOTED][OP] likes this.
  15. Dec 8, 2017 at 12:15 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Taco17
    I would strongly suggest you read the complete section in the manual about engaging and use of 4wheel drive. Then, head out to the woods or field or dessert and gently put the truck through its paces. If possible, actually try a steep incline while locked in 4lo. This will let you know if you have a problem.
    I would absolutely not suggest that you go to the dealership and fraudulently present yourself as an innocent victim in an attempt to lie your way to getting free repairs. Please let us know the outcome.
    Slayer and Newm like this.
  16. Dec 8, 2017 at 1:11 PM
    Taco17
    JULIO
    no, i don't have any intention to do that, I will test the truck and see if anything is wrong, I just hope i didn't F$5^#3 anything. i been reading regarding the issue i had and everyone tells me that it's normal but is it normal to the point that it can't hurt anything if it happens once or mechanically normal and something broke? another response i get a lot is YOU CAN'T DRIVE 4X4 PART TIME IN HIGH TRACTION TERRAIN. Believe me i which i had read the manual but i didn't ,so basically i just want to know base on all of your experiences could that had cause damage?
  17. Dec 8, 2017 at 1:18 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Obviously the possibility exists that you did damage but I believe it is very unlikely. These are well built trucks and very tough.
    This is why I suggest that you take her out and test things on soft ground where you won’t get any binding.
    At this point, you are worried about fixing something that you don’t know is broke.
    T-Rex266 likes this.
  18. Dec 8, 2017 at 1:26 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    Taco - take a chill pill (relax). The Tundras are tough trucks. Find a dirt/gravel road and follow the manual directions to put it in 4W-HI and drive it a couple of hundred feet. Then following directions in manual put in in 4W-LO and drive it 100 feet. This should be all you need to do to ease your mind. Finally, follow the manual and put int back into 2 wheel drive. NOTE- read the entire section of the manual. For example, the manual tells you want to do if 4W-LO light blinks ect.
  19. Dec 8, 2017 at 1:27 PM
    Taco17
    JULIO
    I agree with you. i am worried about something that i don't even know if it's broken, let me ask you would i get any results testing with a boat if i take a boat out from the ramp in 4lo . at this point, i will have my ears open for any grinding noise, i am not sure if you have something else to add like vibration ect...
  20. Dec 8, 2017 at 1:28 PM
    Taco17
    JULIO
    yeah, i know the manual by memory now lol.
  21. Dec 8, 2017 at 1:29 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Do this testing initially on a flat gravel road like @zlaneb said above. Don’t complicate things by adding any additional factors
  22. Dec 8, 2017 at 1:32 PM
    Taco17
    JULIO
    you got it thanks again for the help all !!!! she is going to get dirty tomorrow.
    gosolo[QUOTED] likes this.
  23. Dec 8, 2017 at 1:43 PM
    Taco17
    JULIO
    i forgot to add... I will post the result by Monday.
    gosolo likes this.
  24. Dec 8, 2017 at 5:29 PM
    zlaneb
    zlaneb New Member
    Austin, TX
    I'm sure it will be a simple validation of all things are good. Check back with us when that is done and we can talk about beast mode!
  25. Dec 8, 2017 at 6:04 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I pulled my boat out of side yard the other day and grass was wet. I forgot to take out of 4wd until I got down the road a few miles. All is fine. I normally feel the tightness in steering wheel when I turn out of drive. I have left hunting ranch in Taco forgot I was in 4wd for several miles. No ill effects. Just do not make a habit out of it.
  26. Dec 9, 2017 at 7:04 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Welcome from Texas! Looks like the guys helped you out so no need to repeat anything:thumbsup:
  27. Dec 11, 2017 at 9:41 AM
    Taco17
    JULIO
    HI all , well i didn't had time to do the full test but I did found a nice place about 300 ft L by 150 W that was full of gravel, dirt and some puddles. I put it 4x4HI and felt the gears engaging so i gave it some gas and started drving and truning dindn't feel anything biding or any sound after that took her out of 4x4 put her on straight line again and engage 4x4 did the same thing just a little more agreesive , i did this about 5 times the only thing I felt was that one of the time it took longer to engange ( the light with the car was bliking ) and i gave it a little of gas basiiclly i let my foot out the brake and i felt a little pop like when you put the car in drive on a hill and u have all the weight pressing on the transmission. I didnt do any crazy sharp turns i wasn't sure if i could do that i am planning to go this weekend for a real test, but i wanted to ask again if it was ok to make sharp turns on gravel with 4x4 on .
    4x4_Angel likes this.
  28. Dec 11, 2017 at 3:20 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    I have a few rules I always follow when engaging or disengaging 4Wheel drive.
    1) keep er straight while engaging/disengaging
    2) while truck is slowly rolling let off gas and hit button while coasting. (Seams to work better while moving then in a stopped position)
    3)never turn wheel all the way to one side while in 4 wheel drive( if you can help it)
    When pulling from off road into parking lot/gas station/ driveway or anywhere your going to need to make sharp turns, disengage 4wheel drive so you can.
    4)Never engage/disengage while moving more then 45 mph. I think the manual talked about this and it might be a few more mph but, that's where I draw the line.
    Have fun wheeling,buddy. Good to have you. Cheers!
