Need help: 2019 Tundra - Electrical issue
Discussion in 'Electrical' started by Maanerud1986, Jun 15, 2022.
  1. Jun 15, 2022 at 3:42 PM
    Maanerud1986
    Maanerud1986 [OP] New Member
    2019 Toyota Tundra
    New to the group. Sorry if not allowed.
    2019 Toyota Tundra TRD 4x4 issue.
    When it gets hot outside, my stereo/camera display shuts down. Traction control light comes on. Cruise control stops working. Automatic locks stop working. Once night comes and it cools down, it fixes itself.
    Any ideas?
    Local Toyota dealer is no help even after paying for troubleshooting. No check engine light. No codes being thrown
    Thank you
  2. Jun 15, 2022 at 5:26 PM
    What part of the country are you in? How old is the battery? Heat kills them around the 2 to 2.5 year mark.
  3. Jun 15, 2022 at 5:35 PM
    Maanerud1986
    2019 Toyota Tundra
    Interesting
    CA. Currently about 102 degrees.
    Could a weak battery cause this problem? I would think (uneducated) that it would impact on starting of the engine. No cranking problems. Thank you for the conversation
  4. Jun 15, 2022 at 5:40 PM
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    I’d take it too a parts store and have the battery load tested. That should give you an indication of its health.
  5. Jun 16, 2022 at 4:03 PM
    Maanerud1986
    2019 Toyota Tundra
    Thank you again for the reply @Tundra234 and @“J” I think I’m in the right direction now. I had the battery check and load test and it checked out fine. However, I learned that my alternator is going bad. Had it double checked by someone else and they confirmed it is failing. So Monday, I’m getting that replaced.
    Fingers crossed. Thanks again
    Tundra234 and Scott P like this.
  6. Jun 18, 2022 at 7:21 AM
    “J”
    “J” New Member
    NC
    Do you have anywhere locally that can rebuild them? Much cheaper. Usually a day turnaround. That is depending on supplies on hand.
  7. Jun 18, 2022 at 9:07 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Had a Chevy truck once that a sheet metal screw nicked a wire in the roof during the manufacturing process. Every time the roof would get warm/hot, the sheet metal roof would flex just a little and cause the dome light to come on. Had a heck of a time figuring that out and the Chevy dealership's recommendation was to take the bulb out, lol. No more Chevy's in my future.
