Need Fuel Pressure Testing Help
Discussion in '2nd Gen Tundras (2007-2013)' started by JetJockey, Nov 7, 2019.
  1. Nov 7, 2019 at 11:04 AM
    JetJockey
    JetJockey [OP] New Member
    David
    2007 Tundra 4X4, 5.7L
    Tundra 2007 4X4, 5.7 L. Code P0305 misfire on cyc. #4 & 5 while pulling boat trailer, car shuttered, Check Engine, SVC Off, 4Lo lights all illuminate (vehicle was not in 4Lo). Pulled and replaced all coils and plugs with Denso brand. Notice #4 plug had insulation damage at electrode. Test drove all normal until rapid load placed on engine at 5K RPM, then car shutters, Check Engine, SVC Off, 4Lo lights all illuminated again. Thought it might be a fuel injector on #5, so move injector to another cylinder, problem did not follow. Turning off engine and restarting, engine runs fine until rapid load placed on it again. Wanted to check fuel pressure but found no Schrader valve on fuel bar. Tried to connect with Tee/Schrader valve at fuel feed line feed but found smaller diameter on Tee test kit then Toyota fuel line connector so no go. Is there a specific test kit that works with this engine or a another way to test fuel pressure. Could there also be another malfunction causing this problem with engine under load?
  2. Oct 18, 2020 at 10:45 AM
    Mikey02151
    Mikey02151 New Member
    2010 Tundra 5.7
    I also have a 2010 with the 5.7 and getting misfire on cylinders 7 and 8.... the issue comes and goes and I ruled out the plugs and coils. How does one check fuel pressure on these? Any help is appreciated.
  3. Oct 19, 2020 at 7:15 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Might be able to get some info from code scanner, by viewing live data.
    Edit: I wonder if @Thrussn solved his problem. Sounds like same problem.
