Need front turn signal socket
Discussion in '2nd Gen Tundras (2007-2013)' started by timthetoolman, Feb 9, 2017.
  1. Feb 9, 2017 at 11:14 AM
    timthetoolman
    timthetoolman [OP] New Member
    I didn't turn up anything in the search. I ordered the turn signal socket from Amazon but does anyone know where to get the wiring.
    Not sure what part is shorting out on the front turn signal but when I move the wiring around it starts working again so I figured I'd splice in new wiring and socket.
    Thanks
  2. Feb 9, 2017 at 11:15 AM
    Does the parts department sell pigtails for your socket? I would check.
  3. Feb 11, 2017 at 12:03 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    The toyota dealer has these for cheap, had to replace two on my 4runner and they were around $5 each
    ColoradoTJ likes this.
  4. Feb 11, 2017 at 4:50 PM
    Roman likes this.
  5. Feb 13, 2017 at 1:43 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I should be able to look those up for you. The connector and wires come in two separate parts. What year is your Tundra?
    NewImprovedRon likes this.
  6. Feb 13, 2017 at 3:46 PM
    Berkdawg
    Berkdawg New Member
    2013 Rock Warrior
    Clazzio Seat Covers, Eibach/Toytec Coil Overs (3"), Toytec Boss Rear Shocks, Firestone Airbags
    I am following because my 2013 just started doing this. The wires coming into the connector are broken or something. There is nothing visually wrong with the connector or wires. Please share how you fix.
