Need Cam Tower Leak Fixed, What Else Should I do?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Alex413, Mar 29, 2023.
  1. Mar 29, 2023 at 5:09 AM
    Alex413
    Alex413 [OP] New Member
    Just bought a 2018 SR5 5.7 Double Cab 4x4 3 months ago and kicking myself for not get any kind of warranty with it. Just found out my cam tower is leaking bad and needs repair and quoted $4500. I know I need to get it done, the leak is too bad, question is: Since my whole engine is getting ripped out to fix this, is there anything else I should get replaced while it’s out? Any other seals etc.? It has 77,000 miles on it. Thank you all for your help.
  2. Mar 29, 2023 at 5:24 AM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    They probably sold it to you that way. Maybe see if they will work with you assuming you bought it from a dealer. My 2018 Platinum had to be done as well at 40K. Luckily it was under warranty. Good Luck!
  3. Mar 29, 2023 at 9:12 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    When you say leaking bad, what do you mean? Mine leaks - only enough that it drips on the heat shield in the summer when its really hot. Aside from that, it hasn't gotten worse in 40K miles. Im not touching mine unless it gets much worse.
    Rocko9999 and HulkSmurf14 like this.
  4. Mar 29, 2023 at 9:49 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    You could try switching to 5w30 and see if that helps.
  5. Mar 29, 2023 at 2:20 PM
    Rocko9999
    Rocko9999 New Member
    Yes, quantify bad? If you see lots of old oil, wash it off and monitor how much it leaks.
    FrenchToasty and HulkSmurf14 like this.
  6. Mar 29, 2023 at 7:47 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    I only know of two Tundras having this repair done and both were fixed without pulling the engine.
    Rocko9999 likes this.
  7. Mar 30, 2023 at 8:17 AM
    Rocko9999
    And while you are in there, rebuild the transmission, rear end, reupholster, new paint, etc.
    Wishbone Runner likes this.
  8. Mar 30, 2023 at 8:36 AM
    2mchfun
    I'd go with a valve spring upgrade, starter, waterpump, timing chain tensioners, drive belt tensioner and most importantly an injector upgrade and a supercharger cuz life is too GD short!!
