Need better gas mileage out of my 5.7
Discussion in '2nd Gen Tundras (2007-2013)' started by 603tundra guy, Apr 4, 2017.
  1. Apr 4, 2017 at 4:17 AM
    603tundra guy
    603tundra guy [OP] New Member
    2013 green tundra Tard lifted
    3"front spacer 2"rear blocks
    What can I do to get better mileage out of that beast? I have been thinking of intake and throttle body spacer
  2. Apr 4, 2017 at 4:17 AM
    grundletaint
    grundletaint New Member
    2012 MGM platinum crewmax
    Remove the lift
  3. Apr 4, 2017 at 4:25 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Possibly a bed cover. They say that this helps. I have noticed about .5 better difference in MPG since I put mine on.
    Metro14536 likes this.
  4. Apr 4, 2017 at 4:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Go back to stock tire size, remove lift, get a Prius.
    Intake does absolutely jack shit for the money.
    You bought a tundra because it's an awesome truck and you lifted it because it would look even better......
    be honest, you knew the tundy's got relatively bad gas mileage and the lift/tires would make it worse. NONE of us care about gas mileage when we do any of the above.
  5. Apr 4, 2017 at 4:38 AM
    Pvarela07
    Pvarela07 New Member
    2014 Silver Tundra SR5 TRD Off-road 4x4
    Just getting started
    Tuner might help a bit, in thinking about getting one in the next couple of months.
  6. Apr 4, 2017 at 4:43 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    XxDODSONxX, YotaMan and Backslider like this.
  7. Apr 4, 2017 at 4:51 AM
    CTX84
    CTX84 New Member
    I remember when people were cutting holes in their wheel wells and running a hose into the air filter box. What is that that Toyotas R&D forgot to do when building all Tundras to increase our gas mileage! I might need to go cut my truck up.
    stanky, focal, trayday and 3 others like this.
  8. Apr 4, 2017 at 4:58 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Supercharger
  9. Apr 4, 2017 at 5:18 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    yep, just about the only way to really improve efficiency...that, or don't use the skinny pedal.
    Unfortunately, MPG is definitely a shortcoming of the Tundra, largely in part to the 4.30 rear end (tow package, 4.10 non-tow), but that is also the main reason I bought the Tundra. I, like most Tundra owners, knew what they were getting into and just didn't care. Other truck manufacturers are putting smaller rear ends in their trucks to increase fuel economy and lure potential buyers, but who wants a 1/2 ton truck w/ a 3.08?
  10. Apr 4, 2017 at 6:28 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Stock set-up will be best for efficiency Definitely get rid of leveling blocks and rear blocks. Go with p-rated street tires. Supercharger will help with mpg, but you pay more for premium, so overall, you lose.
  11. Apr 4, 2017 at 7:20 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    As @csuviper saw the other day, spoilers. All about aerodynamics.
  12. Apr 4, 2017 at 7:55 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Don't we all
  13. Apr 4, 2017 at 7:56 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    what the shit is this
  14. Apr 4, 2017 at 7:56 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    trade it in for a prius and your man card
  15. Apr 4, 2017 at 8:10 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    True.. I knew tundras sucked when it comes to gas but the engine blows always the comp!! The room inside the CM is what made me buy... gas went out the window when makin the decision on buying this truck... not sure but adding a tuner for performance help with gas??
  16. Apr 4, 2017 at 8:14 AM
    TXMiamiFan
    Jose
    Daily driver buddy. Its what I did. Got a beater to go back/forth to work. I know, first world solution.
  17. Apr 4, 2017 at 8:19 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Lets run a thought experiment to gain some perspective. Assuming you currently drive 15k / year, and you get 15 MPG. That means that @ $3 per gallon, a 1MPG increase would save you $187.50 per year. So with an intake and throttle body (assuming it would actually give you that 1MPG improvement), you're probably all in at around $400. Thats a little over 2 years before you start to see any real $ benefit.
    Conventional wisdom is that an intake and throttle body will not provide that improvement, so basically you have your self a $400 under-hood ornament.
  18. Apr 4, 2017 at 8:23 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    no doubt and you add in the reliability....its a no brainer!
    not to mention, the slight increase in gas costs are made up by the lack of shop visits! At least it is in my eyes.(considering time and costs)
    Wixo, 040Tundra, Metro14536 and 3 others like this.
  19. Apr 4, 2017 at 8:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  20. Apr 4, 2017 at 9:08 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Trade it in and get a weak EcoBoost. Then you can roll around saying truck YEEEAAAA!
    (please have a since of humor OP ;))
  21. Apr 4, 2017 at 10:03 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    A tundra owner that wouldn't be allowed on here. :D:D:D:D
    RickC, brayan975, Hasteen and 5 others like this.
  22. Apr 4, 2017 at 6:16 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Oh we'd allow it, purely for entertainment purposes.
  23. Apr 4, 2017 at 6:19 PM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Do what I did a week after I bought my Pro... bought an 07 Honda Accord
    No I'm not running up the miles on my new Tundras like I usually do
    Tundyfundy and NewImprovedRon like this.
  24. Apr 4, 2017 at 7:52 PM
    felixth
    felixth New Member
    Felix
    2014 Crewmax Limited
    Nothing yet :)
    I agree with what you guys are saying. You don't buy any Toyota truck for the great mileage. You buy them because they haul the mail and will do it for as long as you own it. I have had Chevy, ford, and Toyota. I sold my Tacoma and bought one of these "new snazzy ecoboost fords". Had it a few months before driving it on a normal day and all lights came on the dash and it went into safe mode. If you don't like the mileage someone is out there wanting a Toyota truck for all the reasons I mentioned. I had a hard time finding a used one. Resale on Toyota trucks is amazing. Not trying to bash on you but you have to realize what you have. I thought that ford had best of all worlds, power, mileage, longevity and looks. Mileage was only ok and I wouldn't trust it to go anywhere. I went on a bit of a rant here but that's what I think!
  25. Apr 4, 2017 at 9:14 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
  26. Apr 4, 2017 at 9:32 PM
    kenomouth64
    Tetrus
    That is the greatest thing I have seen since I saw the new Honda Ridgeline.
  27. Apr 4, 2017 at 9:38 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Compared to my camaro 2ss which uses 93 every fill up I'll drive my tundra all day. I bought a truck for a reason, not to worry about gas mileage and at least with this truck I can use plain Jane 87 octane lol
    Les7311, PLC721 and Law323 like this.
  28. Apr 4, 2017 at 10:46 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Don't you ever speak ill of the greatest truck ever made sir
  29. Apr 5, 2017 at 12:46 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Omg iv been searching for this. I can't keep all my tires on the ground and the truck keeps trying to take off. This high performance mod will definitely help.
  30. Apr 5, 2017 at 4:55 AM
    Fishin1981
    Fishin1981 New Member
    2015 tundra limited crewmax
    Pop and lock, esp storage, access lorado, front tints
    Assuming your experiment was close to realistic, most would be happy with the 15mpg. I'm getting 12.5 at best.
    cjscinta and O'hAodha like this.
