Need battery charger recommendation with Bully Dog
Discussion in 'General Tundra Discussion' started by Jbtaco2002, Jan 3, 2020.
  1. Jan 3, 2020 at 10:05 AM
    Jbtaco2002
    Jbtaco2002 [OP] Almost a Tundra
    San Diego
    nothing cool
    Found a few topics on this subject but wanted to get some opinions...
    my charger is a 10A version but it's a struggle to get voltage to or above 12.1V before the BD tuner let's me reflash.
    i want something that'll pump this to like 14V while charging.
    can i get some recommendations?
    thanks in advance
    JB
  2. Jan 3, 2020 at 10:17 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    This is what I use. Has no problem taking my battery all the way up
    Battery Tender 022-0209-DL-WH 4A Selectable Charger is an AGM/Standard or GEL/Lithium Iron Switchable, 12v or 6v Switchable at 4a, Includes Rings & Clips. It Will Never Over Charge Your Battery https://www.amazon.com/dp/B01K87YZ3C/ref=cm_sw_r_cp_api_i_Eu4dEbWJFG35H
  3. Jun 29, 2021 at 12:35 PM
    TonyPalleschi
    TonyPalleschi New Member
    Tony
    2015 Toyota Tundra SR5 5.7L
    Am I understanding you correctly, I can use a battery charger / maintainer to switch tunes? All I have is an old, big stupid charger and it’s annoying to wrap everything up when I’m done
  4. Jun 29, 2021 at 12:59 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Yup, I just use a cheap one from oriellys when I tuned mine.
    TonyPalleschi[QUOTED] likes this.
  5. Jun 29, 2021 at 1:12 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Optimate 7 Select.
    It has a mode where it will supply power to the ECU even without the battery connected to the engine harness.
    It is pricey.
    Oats87 and TonyPalleschi like this.
  6. Jun 29, 2021 at 6:43 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    I have one of these, because the way I see it, $160 for a charger is a heck of a lot cheaper than the money it costs for a new ECU, not to mention the programming required on it. You can top your battery off with the OptiMate, then put it in "PS" mode when you are programming. Make sure your AC/blower/lights/etc. are all off when programming.
    hagrid[QUOTED] likes this.
