Need Baja Designs Fogs feedback
Discussion in 'Lighting' started by Stocky Balboa, Dec 3, 2019.
  1. Dec 3, 2019 at 10:01 AM
    Stocky Balboa
    Stocky Balboa [OP] New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    I’m thinking about upgrading to these BD lights. Sport wide cornering
    Anyone use them?
    Are they a lot brighter than stock?
    easy to install?
    Are they solid?
    Do they vibrate like the stock setup?
    Plug and play wiring?
    Any pics would be helpful.
    Thanks!
  2. Dec 3, 2019 at 10:03 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Things are super bright, I run the amber every day but I’m waiting for the SAE approved fogs they will be releasing soon( they had released them but pull them to update them for better pattern)
    fliberto38 and Stocky Balboa[OP] like this.
  3. Dec 3, 2019 at 10:10 AM
    Stocky Balboa
    OC , CA
    Super bright is encouraging. How was the install? Any cutting or splicing of the wiring?
  4. Dec 3, 2019 at 10:16 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Super easy and straight forward no cutting at all toughest part is removing the plastic liner from the wheel well
  5. Dec 3, 2019 at 11:13 AM
    fliberto38
    fliberto38 New Member
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
    I have the amber as well. I second the super bright and I am also waiting to see what happens with the SAE approved ones. Super easy to install. I don't use them all the time because of how bright they are, I mainly use them in place of my high beams. And they were awesome at night while in Yellowstone National Park. I also have the clear lights on ditch brackets.
    Stocky Balboa[OP] and Sunnier like this.
  6. Dec 3, 2019 at 11:24 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    CaptJim1794 likes this.
  7. Dec 3, 2019 at 11:27 AM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I have them in amber and I love them.
    Stocky Balboa[OP] likes this.
  8. Dec 3, 2019 at 12:14 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
  9. Dec 3, 2019 at 12:15 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    SoCalTundy[QUOTED] likes this.
  10. Dec 3, 2019 at 12:17 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    U should contact BD they had problems with the lenses and new ones will be getting released, so they will send you new ones once they get approved
    BlueBottle[QUOTED] and Sunnier like this.
  11. Dec 3, 2019 at 12:22 PM
    SoCalTundy
    I'm curious to see how they perform compared to BD. The price on them is really good. They said they were shipping early December when I placed my order.
    BlueBottle[QUOTED] likes this.
  12. Dec 3, 2019 at 12:24 PM
    dlowry81
    dlowry81 New Member
    Doug
    I thought you had the BD pro lights which are brighter than the sports?
  13. Dec 3, 2019 at 1:07 PM
    TheBeast The Beach
  14. Dec 3, 2019 at 1:17 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Maybe I can help. Here are the BD Sports in Wide Cornering. They are definitely brighter then stock. If you want even brighter go for the Pro's. If you drive in snow/rain/fog/dust get the amber...or if you get clear....spend the 11 dollars or whatever and get the amber lenses. I didnt run mine all the time because they are brighter. However I don't think I got flashed from other drivers when they were on. Already put these on the wifes brand new 4runner too. If I ever swap out my factory led's on this Tundra I will run pro's this time since I am not lifted like the last one.
  15. Dec 3, 2019 at 4:41 PM
    Stocky Balboa
    OC , CA
    I did pick these up today. Install is easy, just switch the stock bezel to the new BD.
    One small mistake was I crossed the polarity on the supplied harness and popped a fuse.
    Now the bad, they bounce just like stock. Pretty bummed for $350- I guess it’s Macgyver time to find a fix. Damn...
    equin likes this.
  16. Dec 3, 2019 at 4:45 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Zip tie fixes ur problem
  17. Dec 3, 2019 at 4:55 PM
    Stocky Balboa
    OC , CA
    Good call. Isn’t the zip tie a fix for the light moving in the plastic mount ? i might be misunderstanding the fix?
    My problem is the whole black bezel moves on the truck. The bezel just snaps in the top and bottom but there’s a lot of play.
  18. Dec 3, 2019 at 4:57 PM
    Stocky Balboa
    OC , CA
    Are yours mounted in the stock fog location?
  19. Dec 3, 2019 at 4:59 PM
    Stocky Balboa
    OC , CA
    I was told to JB weld (very small) a couple of spots on the back of the bezel and pop it in. Let it cure etc.
    Not sure about that tho.
  20. Dec 3, 2019 at 5:05 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yes but mine don’t move to much
    Bigboitundra likes this.
  21. Dec 3, 2019 at 5:12 PM
    Stocky Balboa
    OC , CA
    Gotcha. Thanks for the pic. Amber looks great.
  22. Dec 3, 2019 at 5:16 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    That’s exactly what I did. Zip tie on the side of the bracket to secure it. No bounce for me and I’ve had them on since last February
  23. Dec 3, 2019 at 5:17 PM
    Juanjoolio007
    Oregon
    That’s weird that the housings move. Mine didn’t. In either the truck or the 4Runner. Did you make sure the EPDM rubber was on both sides of the tabs on the top I believe? That would help secure it.
  24. Dec 3, 2019 at 5:23 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I heard they are releasing a new version of the sae. Not holding my breath for them. We will see how these dd work.
    I did but I wanted to run aux lights on the streets so I thought I’d give these a try.
    fisherman951[QUOTED] likes this.
  25. Dec 3, 2019 at 5:27 PM
    Stocky Balboa
    OC , CA
    Zip tie like this ?
    equin likes this.
  26. Dec 3, 2019 at 5:28 PM
    Stocky Balboa
    OC , CA
    Yep. Same thing with stock fogs. I do have painted bumper caps, I’ve heard that’s why they are not snug
  27. Dec 3, 2019 at 5:41 PM
    CaptJim1794
    CaptJim1794 New Member
    2016 White Tundra 1794
  28. Dec 3, 2019 at 5:56 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Yes I called last week cuz I was trying to see if I can get them for the BF rebate. They said they are on the shelf just waiting for final approval( certification) so they can release them.
  29. Dec 3, 2019 at 7:03 PM
    Running these, LOVE EM!!! BRIGHT AF!!! No amber lens on my end, Install straight forward, plug in play, just remove front inner wheel liner, simple to do, even a caveman can do
  30. Dec 3, 2019 at 7:26 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
