Need audio advice
Discussion in 'Audio & Video' started by Tigwelder, Dec 20, 2019.
  1. Dec 20, 2019 at 6:44 AM
    Tigwelder
    Tigwelder [OP] New Member
    So far i love the new tundra.
    I ordered and installed audio up grades from tech12volt . 10" lj audio subs with box.
    Lj audio 5 channel 900 amp.
    I installed sound deadner from firewall to rear window.
    Two layers in all doors.
    Infinity 6x9 door speakers .
    Last weekend I installed a bass knob to amp.
    Ive set factory stereo with mids and highs on the high side . Bass about 3/4 . And adjust bass with knob.
    I like the set-up. Nice and quiet inside with little road noise.
    My problem is most of the stereo sound comes from below up into cab area.
    I don't like the lack of crisp clear highs . I would like the highs to be around head (or ear height) .
    I still have factory dash speakers .
    Not sure what I need to bring the collective sound to the to the quality I'm looking for.
    Maybe add sail panel tweeters with bass blockers .
    Not sure what bass blockers to buy though.
    Or better dash speakers ?
    I do like the factory head unit and aps. And don't really want to change it if I don't have to.
    I have around $1500+ in audio now.
    And like it. But just looking for that little extra to bring it all together.
    And help would be much appreciated !
  2. Dec 20, 2019 at 7:02 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Are the sail panel and dash speakers disconnected with the new system that you installed, or are they part of the new system?
  3. Dec 20, 2019 at 7:16 AM
    Tigwelder
    Factory dash speakers still hooked up.
    My truck didn't come with sail panel speakers in front doors.
    I unplugged rear door sail speakers.
  4. Dec 20, 2019 at 7:58 AM
    NoRcptn
    NorCal
    2017 Platinum
    There are several options here you have.
    -For imaging and bringing the sound "up" a sail panel tweeter is probably the best option. I'm not an audio expert by any means, but I don't think with the tweeter properly crossed over that you'll need bass block.
    -You could replace dash speakers with 2 or 3 ohm if not already and draw some more power to the high side.
    -If listening to music from a bluetooth phone. The native music app under settings for iPhone will allow you to adjust the EQ a little more. While not a great fix, it's an option. The same thing goes for Spotify. I have no idea about Android phones, but I'm sure it's the same type of setup.
    But for a permanent solution the Sail panel is probably the best bet as an aftermarket tweeter can be directed to set that sound stage up a little better around head height.
    Bob likes this.
  5. Dec 20, 2019 at 8:55 AM
    NoRcptn
    NorCal
    2017 Platinum
    ^^^im sure James could point you in the right direction for the system you purchased
    Or maybe even tuning what you have.
  6. Dec 20, 2019 at 9:50 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    James also has a dash tweeter upgrade using JL or infinity tweeters.
    You'll need to run wires to your amp though, because the dash speakers are powered by the head unit.
