Need advice regarding steel bumpers with stock suspension.
Discussion in '2.5 Gen Tundras (2014-2021)' started by KingRed, Feb 14, 2019.
  1. Feb 14, 2019 at 3:46 PM
    KingRed
    KingRed [OP] New Member
    I drive a 2017 Tundra 2wd Double Cab SR5 TSS with the 4.6L engine. My factory rear bumper took some damage, so I replaced it with a Fab Fours black steel bumper. Next week, I’ll be ordering the matching front bumper.
    My question is basically can I get away without suspension mods or do I really need to upgrade? Both front and rear bumpers are stated to weigh 185lbs per the Fab Fours website. I seem to have the factory black shocks and struts as of now.
    There are a few conditions that need to be considered:
    1. The front steel bumper will be basic. No winch, no guard rail/bars, no winch mounting plate. (no off-roading)
    2. My truck is already lighter than others because it’s the smaller double cab and the smaller engine vs 5.7L crewmax.
    3. I’m thinking the rear bumper should balance out the front bumper?
    4. I’m not interested in, or have the money for a suspension lift. I don’t want to mess with the geometry of the factory suspension, nor do I want to have to worry about UCAs, difficult alignments, or increased wear on joints.
    5. One of my favorite things about the Tundra is the smooth “Cadillac” ride. Would prefer not to sacrifice that if not necessary.
    So, my primary concern is whether or not the I need to stiffen up the front suspension to avoid problems with bad handling, braking, body roll, sagging front shocks etc.
    If it does require some suspension upgrades, what are the most affordable options? Bilstein 5100s with stock coils? Lowest setting adjustable coil overs and simple Bilstein struts in back?
    Any help would be appreciated. Thanks!
    8791DCAD-26DA-41A2-AE22-4BE3590960B4.jpg 3ADCC406-8B41-4D2A-B6DB-904E060DE357.jpg
  2. Feb 14, 2019 at 5:04 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    I think you will be fine. It might be worthwhile to get your alignment checked after a couple weeks. The front might settle down a little bit. I did notice that the body roll lessened somewhat when I swapped out to Bilstein 6112’s. That is my unprofessional opinion. Good luck! It will look great, and the protection from dings and dents is invaluable.
  3. Feb 20, 2019 at 1:27 PM
    farmer307
    farmer307 New Member
    Leo
    2017 white Toyota Tundra SR5 4x4 crewmax
    Front/rear replacement ranch hand bumpers. Custom hand crafted headache rack with bed rails
    You’ll be ok I’ve had my replacement bumpers front and rear on for a year and had no issues. Even worked great with an impact from a broken trailer I was hauling
    jewsNbrews likes this.
  4. Feb 20, 2019 at 4:32 PM
    KingRed
    Thanks for the encouragement! Appreciate it!
  5. Feb 20, 2019 at 4:44 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I have the fab fours premium bumper with winch. It's 185lbs before the winch. I have rough country n2.0 struts 3". Since adding the extra weight, my front end is sagging and really rough on bumps and stuff now. Going to be upgrading soon.
  6. Feb 20, 2019 at 7:17 PM
    Snowboard Tundra
    Snowboard Tundra New Member
    hey man i have the same bumper setup, what type of lights are those? I'm digging that look vs the Light bar.
  7. Feb 21, 2019 at 1:37 AM
    Berdine
    Binghamton, NY
  8. Feb 21, 2019 at 9:49 AM
    farmer307
    Leo
    180 lbs front bumper
    Although I haven’t noticed any alignment issues it does add extra weight but nothing too crazy. My shocks could be going bad from everyday off-road use so am looking into replacing after I get a level kit
    Luckydog likes this.
