need advice on width
Discussion in 'Wheels & Tires' started by Ufbluewater, May 25, 2019.
  1. May 25, 2019 at 6:30 AM
    Ufbluewater
    Ufbluewater [OP] New Member
    2019 Cavalry Blue SR5
    Wife’s Truck: ordered Bilstein 5100s, looking at tire and wheels,
    Sorry to start a new thread but it’s a lot of work trying to find exact info.
    Wife wants 20” fuel wheels on her new 19 Crewmax 4x4. This thing will never see any mud (we only got 4wd for resale value and emergency issues if we need to pull our 30’ Grady White out of the water.) I ordered a set of Bilstein 5100s and am going to raise them up as high as they’ll go. Looking at 295 tires or 33s I believe will look the cleanest. I don’t want the wheel well to be completely filled up. But what I am really concerned with and don’t know how to find an answer is what offset do I need? I don’t want the tires sticking out. I like the factory stance of the tires flush with fenders but can’t figure out how to do math on the size rims vs the spacing. Can anyone help?
  2. May 26, 2019 at 1:47 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    295’s should fit with minor rubbing. As far as offset you will need +30 or higher to stay inside the fender. I have 295’s on a 18x9 with +25 offset on a 3/1.5 lift. The 295’s fill the wheel-well nicely. I know Fuel makes nice wheels with a +35 offset. I can upload pictures if needed.
    TokerJoker and Ufbluewater[OP] like this.
  3. May 26, 2019 at 5:42 PM
    2chains
    2chains New Member
    Southern Ablerta
    Never too many pics!!
    TokerJoker likes this.
  4. May 26, 2019 at 5:47 PM
    ZPMAN
    Minnesota
    Give Custom offset a call and they should have a answer for you.
    https://www.customwheeloffset.com/
  5. May 26, 2019 at 6:09 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  6. May 26, 2019 at 6:17 PM
    TwistedTad
    Tad
    Canyon Lake, CA
  7. May 26, 2019 at 6:17 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    You ask and you shall receive!!!!
  8. May 26, 2019 at 6:54 PM
    Ufbluewater
    Is there any lift on the front?
  9. May 26, 2019 at 7:00 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    Yes. 3 inches in the front. The Bilstien 5100 on the top set should get you around 2 1/2 in the front but you can always throw a 1/4 inch shim to get another 1/2 inch.
    Ufbluewater[OP] likes this.
