Need a wiring diagram for radio circuit...
Discussion in 'Audio & Video' started by FirstGenTundra1867, Dec 11, 2021.
  1. Dec 11, 2021 at 4:14 PM
    FirstGenTundra1867
    FirstGenTundra1867 [OP] New Member
    Ron
    So. Cal.
    2006 access cab Limited V8 Auto trans 4x4 Tundra
    Removed aftermarket Pioneer unit and re-installed OEM 6 disk radio/cd/cassette unit.
    I'm reinstalling the OEM radio (Model# 86120-OC150) in my 2006 Tundra Limited access cab and need a wiring diagram for the radio circuit. It's needed because the three male connectors that plug into the back of the radio are missing and when I finally succeed in finding three of them, I will likely have to wire them with correct color-coded wires. Thanks in advance for any suggestions, etc. Ron...
  2. Dec 11, 2021 at 4:21 PM
    Aerindel
    Aerindel New Member
    Montana
    alb1k likes this.
  3. Dec 11, 2021 at 4:28 PM
    Aerindel
    Aerindel New Member
    Montana
    It is a 2003 diagram, but if the colors listed match the ones you have, should work. Either way, best I can do.
    1lowlife likes this.
  4. Dec 11, 2021 at 8:59 PM
    FirstGenTundra1867
    Ron
    So. Cal.
    Many Thanks. It might be the only diagram I get here. We'll see. Ron...
  5. Dec 11, 2021 at 11:11 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Hit the wiring diagram thread in my signature.
    Aerindel likes this.
