Need a review by an alignment guru
Discussion in 'Suspension' started by gosolo, Nov 27, 2016.
  1. Nov 27, 2016 at 10:29 AM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    Added 2 CB shims to the drivers side, 1 shim to the passenger side.
    In the rear I added 3 leaf Icon helper packs.
    My concern is that Big O shows I had the same camber going in as when they were done.
  2. Nov 27, 2016 at 1:40 PM
    I would consider a different shop.
    The toe in is out of spec. .24* total toe is max. I would always try to keep my toe as low as possible so tire wear was minimal. (.06-.08* per side)
  3. Nov 27, 2016 at 2:12 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I've been reading the specs on both stock and lifted trucks and that was what I thought too. It drives okay but I think either they wrote this wrong or did the work wrong. I know it could drive alright but wear the tires. Thanks for your feedback!
    ColoradoTJ likes this.
  4. Nov 27, 2016 at 2:15 PM
    With your toe in set like that, the truck will handle awesome.
    Downside is tire wear.
