Need a little help with offsets and fitment
Discussion in 'Wheels & Tires' started by ChrisZTT, Dec 3, 2019.
  1. Dec 3, 2019 at 12:50 PM
    ChrisZTT
    ChrisZTT [OP] New Member
    2018 Super White Platinum CM 4x4
    Hi al . I'm new here and have been reading every post I can but still had a few questions. I have a 2018 platinum CM and I want to lift/level it but still keep a bit of rake. I just ordered a set of Bilsteins 5100 adjustables for front and rear. I think I'm going with 1-2 coachbuilder shims on the front and probably a +2 shackles in the back, not sure if the +3 are better. I hope to fit 35s on it but know it will be tight. I'll do the cab mount chop if needed. Im not going to offroad it, it's a daily driver.
    After all that my question is what offset do I need on the wheels if I want a little poke on the tires. I don't have flares on it but am thinking of doing so eventually. I would like a 20 inch rim so should I go with a 20x10 with a 0 offset? Or a -12? Basically if you could point me in the right direction for a setup with and without flares that will give me about and inch or so if poke/wheel stance that would be great.
    Finally, any opinions on the best rims. I want a black rim with machining. I like the Fuel assaults but not how the spoke flare out so I might curb them. I was also looking at the TIS544.
    I know, lots of questions but I really appreciate you guys even looking at this. Thanks in advance.
    Chris.
  2. Dec 3, 2019 at 2:18 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    So stock offset is +50 to +60 depending on wheels/package. To fit 35s on a leveling kit, you can keep your offset around +20 on a 20x9 and clear without much issues....assuming about a 12" wide tire. Offset is a huge factor when determining fitment of larger tires and some overlook that. You could prob just do 5100's at top setting and leave rear stock and still throw 35s.
    DM 2018 Tundra likes this.
  3. Dec 3, 2019 at 3:23 PM
    I run a 0 offset 18 inch wheel and 34's with Bushwacker flares and a ReadyLift 3/2 kit.
  4. Dec 3, 2019 at 5:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    this is stock tires 255-70 R18 on 18 x 9 +18 offset. no lift.
    after this tires is gone, I'm going to get some bigger tire and level it.
  5. Dec 3, 2019 at 5:42 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
  6. Dec 3, 2019 at 9:52 PM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    +25 offset
  7. Dec 4, 2019 at 3:53 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    How far does ur stick out? Mine is about 1 inch roughly.
  8. Dec 4, 2019 at 7:46 AM
    ChrisZTT
    I like the look of that. What width is the rim? Also what size tire? Thanks.
  9. Dec 4, 2019 at 10:06 AM
    TwistedTad
    Tad
    Canyon Lake, CA
    Method NV 18x9 +25 offset with 295/70/18 Toyo AT2 extremes.
  10. Dec 4, 2019 at 10:13 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
  11. Dec 4, 2019 at 12:12 PM
    ChrisZTT
    Sorry, one more question. If you had a 9 wide and a 10 wide wheel with the same offset would the 10 wide wheel stick out further?
  12. Dec 5, 2019 at 2:23 PM
    TwistedTad
    Tad
    Canyon Lake, CA
    I would not think so. My tires are 11.5 wide so I don't think it would make a difference on either a 9 inch or 10 inch wide wheel.
  13. Dec 5, 2019 at 6:53 PM
    favStaR
    favStaR New Member
    2020 Tundra TRD Sport Premium
    Mine sticks out about 9" :)
