Need a lil help with oil filter
Discussion in '2.5 Gen Tundras (2014-2021)' started by Donn, Jan 4, 2020.
  1. Jan 4, 2020 at 8:49 AM
    Donn
    Donn [OP] New Member
    Donn
    Tundra 2017
    BDS LIFT ICON SUSPENSION
    Hey guys, do you use a impact gun to take off a stuck oil filter canister? I actually gave up. I drained the oil and filled it back up after trying to get the oil canister off even with the oil filter wrench that is specific for the canister. I consider myself very strong actually stronger than most average people not tooting my own horn and I couldn’t get it to budge I literally tried for one hour.
  2. Jan 4, 2020 at 8:58 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Do you have the plastic/factory one? I'd get the metal OEM. I had to use a 1 1/16" socket on the nut portion of the oil filter wrench with 1/2" drive breaker bar. The 3/8" was too puny to get any leverage. I wasn't concerned with messing it up because I had a metal one waiting to replace it.
    ETA: My 1st thought was using a 3/8" to 1/2" drive adapter but didn't have one in my tool box
  3. Jan 4, 2020 at 8:59 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    Try using a dead blow hammer to hit the wrench. I had to do this on my wife’s 4Runner (same canisters). Idk why the dealer puts them on so tight. Oh, and replace it with the aluminum one. You can find it on Amazon
  4. Jan 4, 2020 at 9:00 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Longgggggg breaker bar..when i did my first oil change after the freebies, the oil filter cap was what i felt like glued in place. Needless to say, it cracked and came loose at the same time. Luckily, i had the metal oil filter housing cap ready to go on in its place.
  5. Jan 4, 2020 at 9:03 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    This. Skip the impact gun and use a long breaker bar
  6. Jan 4, 2020 at 9:19 AM
    Donn
    Donn
    Tundra 2017
    Thanks for the fast responses. I will try this and order the aluminum canister.
    thanks
  7. Jan 4, 2020 at 9:20 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    It helps if you change the oil when it’s still warm. Cold metal contracts, so doing an oil change on a cold motor causes the plastic filter cap to damn near seem stuck. Doing it on a warm motor the metal has expanded and things aren’t as snug.
    Think about how it’s done at the dealership. They are changing oil on a warm motor and putting everything back together snug on a warm motor. So once the motor is at ambient temp, it’s going to be even tighter than it was when they tightened everything up.
