Navigation North up by default
Discussion in '3rd Gen Tundras (2022+)' started by burnurass, Sep 9, 2022.
  1. Sep 9, 2022 at 8:49 AM
    burnurass
    burnurass [OP] New Member
    Jeff
    2022 Lunar Rock Tundra Limited with TRD Off-Road
    Most people prefer the map to go the direction the vehicle is going. I prefer NORTH UP view.
    There doesn't seem to be an option to set NORTH UP as default and every time I use the Navigation.
    Anyone find a solution to this? of course I can pick North up everytime, but it doesn't remember the last setting either (that would be OK)
    Hopefully theres an easy fix for this!
    Thanks!
    Carolina Peej likes this.
  2. Sep 9, 2022 at 8:55 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    I believe if you tape the compass icon on the screen it will switch between N up or direction travelling up.
  3. Sep 9, 2022 at 8:57 AM
    burnurass
    Jeff
    That part I get. But it doesn't remember that it's changed to that at the next startup. Most cars it'll remember or you can default to one setting.
  4. Sep 9, 2022 at 10:41 AM
    gmcguire7220
    Ontario Canada
    Ok, mine does. Did you try a reboot. Press & hold power button for 3 secs or so - also check to ensure software is up to date
  5. Sep 9, 2022 at 11:07 AM
    burnurass
    Jeff
    Just for clarification, After you shut the truck off, and you turn the truck back on, it stays north up? I can change to north up, but I have to do it every startup.
  6. Sep 9, 2022 at 12:59 PM
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    Mine stays on whatever was used last.
  7. Sep 9, 2022 at 1:02 PM
    burnurass
    Jeff
    mine too if I leave it on non North up :)
    Can you try north up then see if it stays like that next time?
    thanks
  8. Oct 14, 2022 at 6:55 AM
    kcharris
    kcharris New Member
    Ken
    2022 Toyota Blueprint Tundra SR5 TRD
    Premium Package
    I'm a North up guy as well and it drives me crazy to see the map continually moving. I tried what was recommended, twice actually, but my map does not stay North up. Any other suggestions? I can't believe they don't have a setting for this!
  9. Oct 14, 2022 at 6:56 AM
    burnurass
    Jeff
    I’ve tried all with no success. It’s silly to not have the option to set the default. Literally any car I’ve driven has that feature and it’ll stay north up. I rarely use the Toyota nav and just use google with CarPlay.
    kcharris[QUOTED] likes this.
  10. Oct 14, 2022 at 6:59 AM
    kcharris
    kcharris New Member
    Ken
    Premium Package
    Yeah, I think I'll be switching over to my Android Auto and use Google Maps.
    X42069 likes this.
  11. Oct 14, 2022 at 7:41 AM
    rss29
    rss29 New Member
    22 WCP DC LTD
    My default orientation changes all the time and it drives me nuts. I prefer the angled view but on restarts I'll get some random setting and have to tap the compass icon to fix it. Not a huge deal, but annoying. Every other map has a setting for default orientation.
  12. Jan 1, 2023 at 8:52 AM
    mbkwood
    mbkwood New Member
    2023 Tundra 1794
    Set the map settings you prefer.
    Go to *Settings / Navigation / Calibrate Map / Save.
    This will save whatever state the navigation system is currently in.
    Hope this helps.
  13. Jan 1, 2023 at 9:04 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Yeah I’d abandon Toyota Nav and use Carplay/Android Auto.
  14. Jan 1, 2023 at 1:50 PM
    Space Wrangler
    Space Wrangler New Member
    2023 Tundra
    Thanks for this info. I am also a "north up" person and it has been bugging me to not have it as the default.
  15. Jan 2, 2023 at 1:19 PM
    kcharris
    kcharris New Member
    Ken
    Premium Package
    Tried this. Map still does not stay "North Up." The only thing Map Calibration seems to do is let me adjust where I am on the map and reset North. No change when I start the map system, it still keeps the top of the map the direction the Tundra is going.
  16. Jan 3, 2023 at 10:21 AM
    burnurass
    Jeff
    Same result for me. Still not North up by default.
  17. Jan 3, 2023 at 11:07 AM
    rss29
    rss29 New Member
    22 WCP DC LTD
    Same here. I tried this a couple of times but it still apparently pocks a random orientation every time I launch the map. I like the angled track up view but I'll get North up or track up 2D usually. Not a huge deal, but odd behavior. I prefer using the built in nav vs. Apple maps or Google maps via Carplay.
