Mystery... Pure Hum @ 1400-1800RPM only. WTF?
Discussion in '1st Gen Tundras (2000-2006)' started by agathon, Nov 9, 2023.
  1. Nov 9, 2023 at 9:41 PM
    agathon
    agathon [OP] New Member
    PA
    2000 Tundra 4.7L V8 2WD
    SnugTop camper shell
    After replacement of 1) valve cover gasket, 2) entire exhaust piping.
    Kept/reattached Oxygen sensor at engine end with weld. Done at "good" repair franchise location. Original V8 4.7L engine.
    Immediately noticed low-freq hum. Very pure & steady, deep baritone.
    Only when applying gas & @ 1.4-1.8K RPM.
    Doesn't happen when throttling up in Park.
    Only happens after engine temperature goes above "cold", above the bottom gauge mark.
    Repair place technician said it seems normal. It's not.
    theories:
    * Tranny issue & just coincident with recent work? Fluid pan not changed for over 80K miles. No other issue shifting.
    * Resonant freq. of loose gasket or exhaust manifold or exhaust pipes?
  2. Nov 9, 2023 at 10:00 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Check wheel bearings? Exhaust heat shields?
  3. Nov 10, 2023 at 3:19 AM
    I’m going with exhaust hum or drone. Maybe a hanger, heat shield or connection.
    FirstGenVol and agathon[OP] like this.
  4. Nov 10, 2023 at 5:06 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Did you use OEM resonator and muffler?
    BroHon and Jack McCarthy like this.
  5. Nov 10, 2023 at 5:46 AM
    shifty` Animals and insects don't do drugs
    My eyes would be firmly centered on the exhaust. Did they touch any flanges? Did they take anything out? Did they add anything in? Did they relocate or move anything?
    If this is a "Good" franchise/chain as you say, they'll be more than willing to go on a test drive with you to hear you reproduce the problem, and look into it. The problem didn't exist prior, exhaust is notorious for 'droning' and other acoustics. It stands to reason it's something they did.
    BroHon and agathon[OP] like this.
  6. Nov 10, 2023 at 9:24 AM
    agathon
    PA
    Wheel: But it doesn't occur without throttle up, i.e. coasting - where RPM=0. Could be shield.
  7. Nov 10, 2023 at 9:26 AM
    agathon
    PA
    New muffler & resonator through Meineke.
  8. Nov 10, 2023 at 9:31 AM
    agathon
    PA
    Thanks. -- Forgot to say: no change in engine power/performance.
    They did test drive w/o me. Claimed that they can't hear anything abnormal.
    I'll check w/ dealer/other to use stethoscope type device to pinpoint the source, but that's gonna be hard to do, given the requirements to reproduce the noise.
  9. Nov 10, 2023 at 9:32 AM
    It's definitely something resonating, and resonating in response to throttle, it sounds like. You may very well have an exhaust leak also.
    agathon[QUOTED][OP] likes this.
  10. Nov 10, 2023 at 11:34 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I would agree with resonator for sure.
  11. Nov 10, 2023 at 3:06 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Resonator might not be tuned into the right frequency to eliminate drone since it’s aftermarket.
  12. Nov 10, 2023 at 4:20 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Are the stock resonators tiny glasspacks?
  13. Nov 10, 2023 at 4:44 PM
    Jack McCarthy
    Bill
    North of Boston
    A glass pack is a basic resonator but not all resonators are glass packs.
  14. Nov 10, 2023 at 5:52 PM
    agathon
    PA
    uh.... dunno.
  15. Nov 11, 2023 at 5:51 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    BroHon, shifty` and Jack McCarthy like this.
