Mystery clunk when turning
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Mar 12, 2020.
  1. Mar 12, 2020 at 7:19 PM
    Pucks18
    Pucks18 [OP] Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I have this really annoying clunking/pop problem when turning at lower speeds. Happens when turning sharply. I will turn left and it will pop, then it wont do it again till i turn right tightly. Or if I'm offroad, or turning into an uneven driveway or parking lot that causes my truck to shift side to side, it will clunk/pop numerous times.if im going a low speed i can consistently recreate the noise by swaying the truck left and right, and it seems like the noise goes from left to right too. I can feel it by my feet sometimes too. It is directly related to the body shifting. It is very very annoying. My mechanic already checked the balljoints, and everything else TWICE and says he cant figure out where its coming from. Everything is tight. A lot of other 1st gen owners seem to have this problem. Maybe they screwed up on the frame replacement?. I think it might be the leaf springs possibly. Any ideas? Not a huge problem but just really annoying now.
  2. Mar 12, 2020 at 7:22 PM
    docfnky
    docfnky New Member
    Have you checked the tie rods? Both inner and outer for both sides?
    revtune, ZappBrannigan and MS22 like this.
  3. Mar 12, 2020 at 8:39 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2025 sequoia MGM TRD PRO
    Stock horse
    Do you have a trd front skid plate?
  4. Mar 12, 2020 at 9:48 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Torque your alignment cams.
    Pudge, theBIGnaud, 15whtrd and 2 others like this.
  5. Mar 13, 2020 at 12:47 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sway bar bushing or Tie rod ends.
  6. Mar 13, 2020 at 1:35 AM
    GNTundra
    Gino
    2013 White
    :gossip: Baconator
    joonbug[QUOTED] and 15whtrd like this.
  7. Mar 13, 2020 at 3:26 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Try disconnecting your sway bar end links from the front - its free - to eliminate all that jazz to diagnose.
    Steering rack bushings and end link bushings (sway bar) are common issues and known to cause this.
    Aww Puck! I just noticed you mentioned you think its the rear leafs. Is the noise coming from front or rear?
  8. Mar 13, 2020 at 4:40 AM
    Pucks18
    @noahrexion it sounds like its coming from the rear but it feels like its from the front!. My mechanic checked everything on a lift and he drove it to see if he could identify the sound. Nothin. Ill just do it myself and check it once illinois weather gets nice n warm
  9. Mar 13, 2020 at 4:59 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    We dont have trd skid plates on 1st gens.
    Pucks18[OP] and Outbound like this.
  10. Mar 13, 2020 at 5:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I would agree with tie rod ends or something steering related. Something is binding up, like a lack of grease on an old worn out part.
  11. Mar 13, 2020 at 5:40 AM
    Professional Hand Model
    Hand Protectors
    I’ve had this problem for 3-4 years. Only happens on slow sharp turns going up an incline or driveway apron.
    Narrowed it down to the rear leafs. My leaf were splayed and the silencer pads worn or missing. The bushings in the leaf eyes may be worn, as well, but can’t see them without removal.
    I installed some ghetto silencer pads using composite shims forced between the leaf tips. The sound reduced and changed so I knew I was on to the problem source. I also sprayed loads of PB penetrator on the leafs and that changed the sound and almost eliminated it. Lo, I need new leafs but its not priority and the sound is barely there at so minimal times its not worth tackling at this time.
    Filthyphil and Pucks18[OP] like this.
  12. May 21, 2020 at 12:33 PM
    Pucks18
    Figured it out, its my leaf springs, right under the shackle where the two main leaf springs are touching. The shackles toward the front of the car
    bmf4069 and Toyotoholic like this.
  13. May 21, 2020 at 2:57 PM
    Pucks18
    Trucks got 134,000 miles, 2001
  14. May 21, 2020 at 3:20 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Get yourself some Teflon pads
