MY23 Mass Air and Lean Codes
Discussion in '3rd Gen Tundras (2022+)' started by ToniThe7iger, Aug 30, 2024.
  1. Aug 30, 2024 at 5:16 PM
    ToniThe7iger
    ToniThe7iger [OP] New Member
    Story: Yesterday morning I was heading to work and my truck started hesitating, power would surge, then it leveled out. A few more miles down the road it gave me power reduced, check engine, hybrid malfunction, and all the safety tech disabled warnings. I took it to the dealership and they told me it was bad gas. The computer showed mass air and fuel lean codes so they tested the gas and it “looked bad.” Then they told me I just needed to drive the rest of the gas out (had a quarter tank left). I asked them if it would be better to fill it up and they said I didn’t have to, the truck should be able to handle the bad gas. So I took them at their word. I made it less than a mile down the road before the warnings came back. I managed to roll into a gas station and I filled it up. Then it wouldn’t start at all. Had it towed back to the dealership and I am now waiting until after Labor Day for them to get around to looking into it.
    I’m confused that after burning 3/4 of a tank of gas it would finally start having issues. My guess is the fuel filter is clogged or having issues. That or the O2 sensors are bad. The dealership seems like they’re leaning towards just calling it bad gas since that’s not covered under warranty.
    Anyone have a similar story or mechanical insight?
  2. Aug 30, 2024 at 6:04 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Toyota doesn’t use fuel filters. It’s just a sump pump type design. The trucks under warranty. If you haven’t modified the intake. Ride it out and see how it goes.
    ToniThe7iger[OP] likes this.
  3. Aug 30, 2024 at 6:25 PM
    ToniThe7iger
    Bone stock. Everything is covered under the factory warranty except in the case of bad gas. It doesn’t sound like it to me because of the mass air flow code but I’m far from an expert.
  4. Aug 31, 2024 at 4:42 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    So what code did you get? What number?
  5. Aug 31, 2024 at 5:38 AM
    ToniThe7iger
    P0171 (Lean Fuel Bank 1 and 2) and P0101 MAF.
    Tundrastruck91 likes this.
  6. Aug 31, 2024 at 12:05 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    T-SB-0030-23
    Timmy23 likes this.
  7. Aug 31, 2024 at 12:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Probably should’ve gotten a gas sample before adding more gas. This is the 3rd or 4th time hearing bad gas in the last few months here.
    Breathing Borla and Blufin like this.
  8. Sep 1, 2024 at 1:26 PM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    50 years of driving in the US, Mexico and Western Europe and I've never heard the lazy excuse "bad gas".
    joonbug[QUOTED] likes this.
  9. Sep 1, 2024 at 6:54 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    This and in an area that has had many many inches of rain in recent months. Seems common more
    and more.
  10. Sep 1, 2024 at 7:06 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    This, read it.
  11. Sep 4, 2024 at 6:06 PM
    ToniThe7iger
    Finally got some news on my truck. Apparently it's a bad pcv valve. We'll see I guess.
    Black widow TRD likes this.
  12. Sep 4, 2024 at 6:08 PM
    Breathing Borla
    Northern Illinois
    it happens especially with the major oils pulling out of the market long ago, your now left with some stations doing their own compliance and maintenance and poof UST failure and water in the system
    we see it often
