My tundra
Discussion in 'Wheels & Tires' started by Soloartist, Aug 4, 2019.
  1. Aug 4, 2019 at 2:58 AM
    Soloartist
    Soloartist [OP] New Member
    2015 tundra 4.6 v8 sr5 double cab
    K&N cold air intake system. Flowmaster exhaust (dual all the way back)
    I'm New here so I how I'm doing this correctly. I had a question regarding the info provided on "tires and wheels". I have a 2015 tundra double cab and when I bought it, somebody had already installed 22" rims and tires on it. Yet it seems to drive fine....is there something I should be concerned with?
  2. Aug 4, 2019 at 4:29 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
  3. Aug 4, 2019 at 4:30 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!
  4. Aug 4, 2019 at 4:50 AM
    Welcome from NY.
  5. Aug 4, 2019 at 5:15 AM
    koditten
    Kirk
    Midland of the Mitten
    Do you like the looks of it? Any tire rubbing when you make sharp turns?
    If you don't mind the look and there is no tire rubbing, then you are in good shape.
    Just be aware that 22" tires are more expensive and there is not as many choices when it comes time to replace them.
    Welcome from Michigan
    Kerch71 likes this.
  6. Aug 4, 2019 at 6:03 AM
    Welcome from Colorado. You should be fine. If you plan on doing a lot 4 wheeling, you will be better off downsizing to an 18.
  7. Aug 4, 2019 at 6:43 AM
    Blueknights75
    Ron
    Clayton, NC
  8. Aug 4, 2019 at 7:15 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    22 inch?.... If you like it, that's all that matters. I'm old and slow. Built for comfort, not for speed
    The only thing is you'll have a rougher ride without sidewalls to flex.
  9. Aug 5, 2019 at 1:57 AM
    Soloartist
    Thank you all for your welcomes and responses to my question. I actually think they look great and the tires do not rub. Won't be doing much off roading seeing how it's not 4 wheel drive.... Thanks again.
  10. Aug 5, 2019 at 4:13 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and :worthless:
  11. Aug 15, 2019 at 10:07 PM
    Soloartist
    Thank you
  12. Aug 16, 2019 at 2:55 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. Aug 16, 2019 at 3:28 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I second this motion :thumbsup:
    Hey there from Virginia!:mudding:
