My tundra is giving me a greaf
Discussion in '1st Gen Tundras (2000-2006)' started by sourdough58, Dec 10, 2021.
  1. Dec 10, 2021 at 6:20 AM
    sourdough58
    sourdough58 [OP] New Member
    2002 Tundra
    Sometimes while driving my engine cuts out (dies) but if I pump the gas or put the gas pedal to the floor the engine starts up again with some popping back thru the intake, If I hang in there it will do this for several cycles and will straighten out for some time may be 1 week or several mos. and then back with the same problem again. Could it be the o2 sensor?
  2. Dec 10, 2021 at 6:23 AM
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    you should clean you throotlebody waffer. it ease. use tb cleaner and soft clean rag. no more greaf after.
    bmf4069, Dunk and NWPirate like this.
  3. Dec 10, 2021 at 6:27 AM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    An o2 sensor will not cut fuel or spark to zero. It will also give you a check engine, if it is not happy. Are you getting check engine light for misfire? Check battery cables and grounds first. All the grounds in the engine compartment you can find the bigger the cable the better.
    Toyotoholic likes this.
  4. Dec 10, 2021 at 6:31 AM
    sourdough58
    2002 Tundra
    Thank you all I will try this.
    Punk1974 likes this.
  5. Dec 10, 2021 at 6:34 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome to you.
  6. Dec 10, 2021 at 6:36 AM
    NWPirate
    Zach
    WA
    Possibly coil packs going bad.
    Clean MAF sensor too with proper cleaner. No rags though, only the spray. This should relieve some of your greaf.
    Punk1974[QUOTED] likes this.
  7. Dec 10, 2021 at 9:36 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Any codes on the OBDII scanner?
    bmf4069 and Punk1974 like this.
  8. Dec 10, 2021 at 9:46 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    And use a decent fuel when filling her up.
    NWPirate likes this.
  9. Dec 10, 2021 at 6:07 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    I used to do that, but I drive 40k a year and can’t afford that fancy stuff. I use Gas Buddy app to find the cheapest gas imaginable lol. I throw in a bottle of Amsoil fuel system cleaner once a year and call it good :rofl:
    Aerindel likes this.
  10. Dec 10, 2021 at 7:56 PM
    Nowhereman
    Al
    Monterey Bay area
    Really?, and how is that working for ya........:crapstorm:
  11. Dec 10, 2021 at 8:07 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Well, the cheapest gas I can find is about $4.39, so I’d say pretty $hity :poking: :rofl:
    But so far I haven’t had any issues with the cheap gas. I have 4 first gens and combined over million miles.
  12. Dec 11, 2021 at 4:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    This. Check the codes.
  13. Dec 11, 2021 at 5:42 AM
    10 blue trucks
    04 4WD RCLB
    Neglected toyotas commonly run the first 250,000 without complainmt. Its the second 250,000 where it all comes back to haunt you.
    coldcanuk, Nowhereman and Punk1974 like this.
  14. Dec 11, 2021 at 12:41 PM
    shifty` Animals and insects don't do drugs
    People who know about it, know about it. It's solid stuff. I always put a few drops in each cylinder of an engine that's been sitting a day or three before firing up, or before storing - you can rest assured it won't have any dry-fire damage, nor freeze up. Stuff is awesome.
    But I typically opt for SeaFoam in my tank and oil for routine maintenance. 1oz per quart in the oil 500-1,000 miles before an oil change, and 1oz per gallon in the gas tank whenever I want a top-end clean, or 2oz/gal on any vehicle new to me. It's a highly refined petrol product so no harm comes with doubling or tripling their suggested amt.
    dinosaur likes this.
  15. Dec 11, 2021 at 2:16 PM
    Sirfive
    Sirfive Master Procrastinator
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Mmo has been a godsend for stuff that sits. I learned about it tuning lister 6hp singles that ran airpumps for underwater divers. When you want an engine to be run hard and put up wet, a little mmo goes a long way. Works on chainsaws and weedeaters, too.
    I heard one of the ingredients is the souls of thankless laborers, but its not listed in the msds.
    https://www.marvelmysteryoil.com/media/1256/marvel-mystery-oil.pdf
    bmf4069, dinosaur and Tundratoofun like this.
  16. Dec 11, 2021 at 2:22 PM
    Nowhereman
    Al
    Monterey Bay area
    You'll see it on tear down..
    Diablo169[QUOTED] likes this.
  17. Dec 11, 2021 at 2:26 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    You should check your air filter. And make sure it is clean.
    You should check your PCV valve. And make sure it is operating properly.
    Or. Hell. Just replace them both.
  18. Dec 11, 2021 at 4:57 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Marvel Mystery Snake Oil :rofl:
    Just kidding, I’ve always heard great things about it, especially from the old timers. Iv’e never run it though.
    Tundratoofun likes this.
