My truck won’t start!
Discussion in '2nd Gen Tundras (2007-2013)' started by Dstarr, Sep 10, 2020.
  1. Sep 10, 2020 at 1:36 PM
    Dstarr
    Dstarr [OP] New Member
    2010 Toyota Tundra
    I just bought a 2010 Toyota Tundra. 95k miles and it was working well, haven’t even put 10 miles on it and the thing won’t start! No lights or nothing. Took it to the mechanic and the battery is practically brand new. I did lift the shift lever just a touch and then the truck started. Now it won’t. I am getting frustrated. So please help me!
  2. Sep 10, 2020 at 2:07 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I would take a look at the harness to the shifter, ensure its all the way in... You stated you raised the shifter may cause issues with grounding as P and N require grounding so it can trigger the starter and allowing you to turn on the truck. If the shifter can't ground then you wont be able to turn on the truck since it thinks its in R, D, S. At least that's my understanding on the shifter and you claiming on raising it....
  3. Sep 10, 2020 at 2:10 PM
    Kanobi13
    Kanobi13 New Member
    Welcolme i would take it back with less than 10 miles you put on it
    BravoDeltaRomeo likes this.
  4. Sep 10, 2020 at 2:15 PM
    Dstarr
    2010 Toyota Tundra
    I bought it private sale from a guy. The shifter was just a tap. Never anything to push it into another gear
  5. Sep 10, 2020 at 2:38 PM
    Kanobi13
    Kanobi13 New Member
    Cancel the check until they fix it
  6. Sep 10, 2020 at 8:15 PM
    ajax1
    ajax1 New Member
    2012 black trd limited modded up
    Tires, suspension, bumpers, soft topper
    I had a land cruiser that would do this , smack the shifter and it would start. This was caused by the nss. To not have to smack the shifter you had to put it into park firmly.
