My Traeger Pellet Smoker/Grill Adventure
Discussion in 'Food Talk' started by csuviper, Jun 14, 2017.
  1. Jun 14, 2017 at 9:02 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Just recently purchased a Traeger Pellet Smoker/Grill. Decided to go with the Costco special edition one. Same size and price as the lil Tex but comes with a warming compartment, lower storage shelf and a cover. Love it.
    This forum is for me at show you the meats I have cooked on it and ask for or give tips and advice.
    Abrams65, cmrock, Black Wolf and 7 others like this.
  2. Jun 14, 2017 at 9:02 AM
    csuviper
    Broomfield, CO
    First thing I did when I got it home is set it up and test it out. There was some assembly required but it came with a nice package of hardware and all the tools needed.
    When starting up the first time you have to prime the auger and then run at highest temp for 45 min to season the grill.
    The i got right to work on grilling up some BBQ chicken. Can't find the pic of these at them moment. Maybe I didn't take any.
    Eclipsed & Floating likes this.
  3. Jun 14, 2017 at 9:02 AM
    csuviper
    Broomfield, CO
    The next thing I made were some nice breakfast bites. Added cheese and ham to the middle of some breakfast sausage. The wrapped it in bacon and smoked it.
    They were very good.
  4. Jun 14, 2017 at 9:02 AM
    csuviper
    Broomfield, CO
    Then I did some jalapeño bites and more chicken legs and filet menon steak with sweet potatoe. The filet was absolutely amazing!!!
  5. Jun 14, 2017 at 9:35 AM
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    I've been looking at these.
    Sub'd
    MotoTundra likes this.
  6. Jun 14, 2017 at 9:40 AM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
  7. Jun 14, 2017 at 10:14 AM
    Colorado meet and eat in Broomfield.....
  8. Jun 14, 2017 at 11:45 AM
    csuviper
    Broomfield, CO
    The most recent endeavor was smoking a pork shoulder for BBQ pulled pork. Cooked at 225F for 9 hours. Dry rub on it and sprayed here and there with apple juice. Cooked it till 195F. Was good but a little dry. I didn't wrap it at all and didn't let it rest after like I should have. Still learning.
  9. Jun 14, 2017 at 11:51 AM
    Was this your first one? Looks great to me. What kind of pellets are you using?
  10. Jun 14, 2017 at 12:25 PM
    Borgs
    Borgs New Member
    PA
    I do brisket on my Traeger. Insane. Ribs and roasted chicken are awesome too. I also smoked salmon, really good. Best and easiest (fool-proof) so far has been brisket.
    Patriot likes this.
  11. Jun 14, 2017 at 1:12 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    My thoughts exactly.
  12. Jun 14, 2017 at 1:48 PM
    csuviper
    Broomfield, CO
    Very first ever pulled pork I have ever ever made.
  13. Jun 14, 2017 at 1:49 PM
    csuviper
    Broomfield, CO
    Brisket or ribs will be the next thing to do on it. Any tips for the brisket?
  14. Jun 14, 2017 at 1:52 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
  15. Jun 14, 2017 at 1:55 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Like I don't spend enough $$ due to this forum already, Brain needs to drop another BBQ thread on me like this! :censored::frusty:
  16. Jun 14, 2017 at 2:26 PM
    csuviper
    Broomfield, CO
    I always try to make others wallets as light as mine.
  17. Jun 14, 2017 at 3:12 PM
    Darth Tundra
    Curt
    17 CM TRD Black
    Nice Brian....im going to get mine at Costco as well....cant wait !!!
    Black Wolf likes this.
  18. Jun 18, 2017 at 6:30 PM
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    IMG_3780.jpg Bacon wrapped shrimp and some small lobsters on the traeger.
    Black Wolf, KB Voodoo, rons23 and 2 others like this.
  19. Jun 18, 2017 at 7:31 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    On the pork butt,
    Don't trim it, if you did. Some folks will cut the fat cap off, do not, leave it on and cook it with the fat cap up.
    Bump up your temp to 250 - 260. do a 9-10 hour cook time, trust me on this. Wrap it when the fat cap splits, should about the 6 hour mark.
    I use foil, heavy duty two sheets. The bone in the meat should just start to wiggle but come come out, yet. There should still be resistance.
    When you wrap it give it a good spray with apple cider vinegar, wrap it tight, not loose, then back on the heat.
    After 9 - 10 hours, check your temps, 195 -205 is where it should be. Remove it from the heat and let it set for 1 hour. This is a must, just walk away, make your sides, watch tv, whatever but do not touch that butt for one hour.
    Then you are ready to unwrap, leave it in the foil, that bone should slide right out nice and clean and that meat fall apart and be nice and juicy moist.
    Trust me on this.
  20. Jun 18, 2017 at 7:34 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Good choice on the heat. Can't ask for a better grill. Made right here in Salt Lake!!! :thumbsup:
  21. Jun 18, 2017 at 8:06 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    @csuviper I'm assuming with the treager you can actually adjust your heat with pellets. Is that right, or am I off base?
  22. Jun 18, 2017 at 8:22 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    How big of a shoulder was that?
  23. Jun 18, 2017 at 8:24 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    http://heygrillhey.com/
  24. Jun 19, 2017 at 2:35 AM
    PermaFrostTRD
    Northern NY
    Get a digital thermometer with 2 probes one for the grate temp (to set next to your meat) and one to place inside your meat. Then you *know* your temps.
    Next, Get some duct work to extend the chimney opening to the grate level. That way your smoke sits on the meat longer.
    Next, get a cheap loaf of white bread and set pieces of bread until the entire grate surface is covered. Stick your grate thermometer in the middle. Set your traeger for 250-300' to toast the bread. Pay attention to what your grate probe reads. (Should be pretty close). About 5-10 minutes or so (depending on temp) your toast should be ready. That will determine your hot and cold spots on the grate. Traegers cook pretty even but you will still notice some difference.
    Finally for your next pork shoulder/butt. Stick a small aluminum brownie pan towards the fire box (the "hot end" of your grate) and fill with water. This will help with moisture. Don't try to add beer or juice for "flavor" it doesn't do anything but make your tray messy.
    Instead of just doing 6hours then wrapping until 9 or 10hrs follow your meat probe temperature. Butts shoulders etc will cook differently even at the same weight. Wrap at 165 (after the "stall") and then add a little beer/juice to wrap, cook till 195-205. But as mentioned above take it out. Wrap the foil and pork in an old shitty damp towel and toss it in your old cooler (now that you likely just group bought a shiny new Orion cooler) :bananadance:
    And WAAAAIIIIITTTT an hour or so.
  25. Jun 19, 2017 at 4:02 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Welcome to the world of Traeger smoker grills haha. :yay:We have owned ours a little over two yrs this past April...it's really an awesome smoker/grill. Cook on it at least once or twice a week. Last week baby backs haha.
    Our Lil Texas Elite- I vacuum out the wood ash and change foil after every cook. After a quick cool down its rolled right into the basement for storage. I do not leave it plugged in when not in use.
    Was given this awesome Igrill meat thermometer as a gift when I retired by a buddy of mine who knows I own a Traeger. The Igrill mini essentially is a meat thermometer you harpoon into a turkey, a Brisket, a Boston butt, whole shoulder. It sends the internal temperature to an app on your iPhone. I put the beast on the smoker and go run errands in town or do other things rather than babysit a grill. With the Igrill always know exactly what the internal meat temp is. It's great when smoking a beast overnight or during the winter. I love not having to shake the ice off my ass standing over a smoker when it's freezing outside. :rofl:
    Love this slow and go pellet smoker.
    Ordered a set of these pit gloves off Amazon several months back, they work great when pulling ribs, chicken, butts, or turkey off the smoker. They wash up great and are ready to go again.
    My pointers-
    Vacuum out the old cold ash after each use, not required but I do it anyway.
    Spray your grill with a cooking oil..olive oil, vegetable oil. It cleans up much easier.
    Use foil to cover your heat defuser- makes clean up a breeze.
    I store mine unplugged (electrical surges are tough on electronics) inside out of the weather.
    Enjoy!
    Enjoy your Traeger!
    aperezsh, Black Wolf and csuviper[OP] like this.
  26. Jun 19, 2017 at 4:07 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Damn, I looked at this and instantly became hungry. Looks damn good.
    Wvmoonshiner and Patriot like this.
  27. Jun 19, 2017 at 4:29 AM
    Patriot
    Patriot Member
    aperezsh likes this.
  28. Jun 19, 2017 at 4:50 AM
    Borgs
    Borgs New Member
    PA
    Brisket is the easiest thing to make I think. The simple recipe in the Red Traeger recipe book that came with my smoker is simple, and yields great results. Basically rub with salt and pepper or another rub of your choice, wrap in foil for night in fridge, then low and slow all next day. I made 3 lbs in 6 hours, larger pieces of meat obviously will take much longer. I may be oversimplifying a bit but not by much. Can't mess it up if you watch your internal temp- and you cook it slow enough. Make sure you have a good electronic meat temp probe, and give it time to rest after you hit the 206 degree temp mark. So good.
    Patriot likes this.
  29. Jun 19, 2017 at 5:01 AM
    Patriot
    Patriot Member
    Brisket...lol
    9# beast
    Boston Butt...
    aperezsh, Black Wolf and Darth Tundra like this.
  30. Jun 19, 2017 at 5:23 AM
    Borgs
    Borgs New Member
    PA
    How long did it take to do 9 lbs brisket???
