My Pro has Gangsta Lean
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by TexasMofo, Mar 7, 2017.
  1. Mar 7, 2017 at 1:35 PM
    TexasMofo
    TexasMofo [OP] New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Is it normal for there to be 1 inch height distance from the driver to passenger side? Driver side rear of truck measures just under 39inches and passanger side measure 40 inches. How do I fix this? I don't want the gangsta lean
  2. Mar 7, 2017 at 1:38 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hey Chad, how are your front measurements?
  3. Mar 7, 2017 at 1:42 PM
    TexasMofo
    Chad
    Front measure even 38.5 inches each side.
  4. Mar 7, 2017 at 1:47 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    2016 CrewMax TRD PRO
    Full gas tank? It's on the drivers side / rear.
    zcarpenter92 and dcsleeper408 like this.
  5. Mar 7, 2017 at 1:49 PM
    Fuel tank
    Battery
    Both on drivers side
  6. Mar 7, 2017 at 1:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    1" is more than most. Front leaning is more common than the rear leaning, also. Raising the front drivers side will help the rear. I'm not able to explain why, ask @Coachbuilder1
    Many of us have added 2 of his shims to the drivers side and 1 shim to the passenger side and this helps.
    Hope this helps you.
    Law323 likes this.
  7. Mar 7, 2017 at 1:53 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    1 inch seems like a lot. I thought it usually showed up in the front and that's why people sometimes put a CB shim on top of the driver side C/O. Sounds like there's something wrong with a leaf. I don't have any other idea. Hopefully someone more knowledgeable will chime in soon.
  8. Mar 7, 2017 at 1:55 PM
    TexasMofo
    Chad
    Gas tank is on that side but it's not a full tank.
  9. Mar 7, 2017 at 1:56 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Ha ha. The knowledge started pouring in before I could finish typing.
  10. Mar 7, 2017 at 2:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    So it's just the rear and not the front? Strange. Make sure you measure from fender to center of wheel. Takes tire pressure and tread out of the equation.
  11. Mar 7, 2017 at 2:05 PM
    BRNG ITT
    BRNG ITT New Member
    San Antonio, Texas
    Sounds silly, but ruling out the obvious. Tire pressure okay? I think an 1" compression in the tire would be noticeable though.
    Edit: just noticed joonbug mentioned this.
  12. Mar 7, 2017 at 2:07 PM
    TexasMofo
    Chad
    24 driver 25 passenger
  13. Mar 7, 2017 at 2:08 PM
    TexasMofo
    Chad
    Pic doesn't do it justice but you can see it
  14. Mar 7, 2017 at 2:12 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    try front from fender to center of wheel too.
  15. Mar 7, 2017 at 2:16 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    That's weird. Try tire pressure, check the leaf, if all else fails, bring it to the dealership it could be a bed mount problem.
  16. Mar 8, 2017 at 11:23 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I'm glad I'm not the only one, who noticed this. I Have a 15 PRO CM and mine does the same. I work at a Toyota too, and I have been able to compare measurements to all pros across the board. I've checked 3 other 15 pros and all measured the same as mine, 17 pros do it as well but doesn't seem as noticeable but they do it too. I've deemed it normal, fuel tank,transfer case(leans left), front diff, and Driver of course all on that side. I have check ride height measurements per TIS too and mine is still in spec. I just got shims shackles & bigger tires and called it a day.
  17. Mar 8, 2017 at 11:28 AM
    TexasMofo
    Chad
    Thanks for the reply. If there was something wrong I just wanted it fixed before I did my shims and shackle.
  18. Mar 8, 2017 at 11:44 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    No problem. Nothing wrong that I've seen, I asked my FTS about it and he said he would look into and let me know if he hears anything. Mine did it before my lift and i didn't see anything broken, out of place or bent so I just went with it.
  19. Mar 8, 2017 at 12:20 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm pretty sure fords all lean to the passenger side cause of the fat wife problem.
  20. Mar 8, 2017 at 5:31 PM
    TexasMofo
    Chad
    Lmao :rofl:
  21. Apr 4, 2018 at 11:51 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Rather than start a new thread I will piggyback on this one. Not a 3rd Gen or a Pro, but similar issue. My front is the same measurement each side, my rear is 3/4" lower on the drivers side.
    2010, 4x4.
    Has anyone successfully leveled the side-to-side lean?
    Did you use a front spacer on top of the coilover? Might seem counter intuitive, but apparently this has a lot of effect on the rear ride height.
    Did you use a small block spacer in the rear? @Toytec Lifts makes a 1/2" block for the rear, does it work?
    Toytec Lifts likes this.
  22. Apr 4, 2018 at 11:54 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Tundra_power and OBXTundra like this.
  23. Apr 4, 2018 at 12:52 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Lmao! That’s good they have a ford than to get their wife’s walking all the time or pushing the ford :rofl:
    gosolo[QUOTED] likes this.
  24. Apr 4, 2018 at 1:15 PM
    TheBeast The Beach
    I had about 3/4 to 1" lean on front driver. I added turns to my driver side coil over to compensate for the lean.
    OBXTundra and Y0TA PR0 like this.
  25. Apr 4, 2018 at 5:13 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I have fixed height 3" lift coilovers, otherwise that might have been an option.
    My front is the same height each side. I think I will give the 1/2" rear shim a try.
    Anyone else running the 1/2" rear spacer to correct the lean?
