My Morimoto Bi-LED retrofit projectors with DRLs
Discussion in 'Lighting' started by ruiner, Mar 8, 2018.
  1. Mar 8, 2018 at 5:01 PM
    ruiner
    ruiner [OP] New Member
    2017 Tundra CM 4x4
    Upon buying my 2017 Tundra CM Limited, I watched the forum for a while to see what members were using for aftermarket headlight solutions since the stock OEMs pre-2018 were utter crap.
    I see the Spyder setup, 2018 OEM LED headlights, other LED setups, swapping bulbs into the stock projectors, various other HID solutions, etc. I bit the bullet and decided to go for a Bi-LED projector setup offered by forum member @eledobleu and couldn't be happier.
    I decided on the Morimoto Bi-LED projectors with a Morimoto DRL strip that has switchback functionality and a turbine shroud. I also had him paint the stock reflectors black (as I didn't need them anymore).
    They turned out incredible and were well worth the money. Some people will say that LEDs don't have the width of the HIDs, and that IS true, but it's not a large enough difference to me. This is especially true when you compare them to the stock OEMs (both halogen and LED on the 2018s). Also, the LED projectors lack the complexity of an HID setup (ballasts, ignitors, bulbs, etc). This setup should last around 12-15 years depending on how often you run your headlights.
    I'll happily answer any questions that you guys might have. It was a relatively easy install and config - 100% plug-n-play for all but the the DRL delete mod which just requires a de-pin under the dash.
    Completed build:
    Mounted on the truck:
    Daytime Running Lights (DRLs):
    Switchback for blinker/hazards:
    Lights on in the daytime:
    Lights on at night (camera iris closed):
    Lights on at night (camera iris open):
    Pudge, Ostrich, Augparra and 7 others like this.
  2. Mar 8, 2018 at 5:04 PM
    ruiner
    2017 Tundra CM 4x4
    Some night shots to show real world use...
    A foot away from my garage door. The Morimoto 'M' can be blocked out if you want. It should give you an idea of the beam pattern:
    Low beam into the woods - nice cutoff line:
    High beam into the same woods:
    headlights off looking down the road (the DRLs were on as the truck was running):
    low beams on the same road:
    Ostrich, Gtfour43, Augparra and 7 others like this.
  3. Mar 8, 2018 at 5:10 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Sweet!
    GodlessPro and ruiner[OP] like this.
  4. Mar 8, 2018 at 6:23 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    ruiner[OP] likes this.
  5. Mar 8, 2018 at 6:57 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Saved a little $ and went with the Profile Led with LEd strip from same source. Very happy after being disappointed with stock halogens. Also added Lasfit led bulbs to fogs. Rarely use brights now. I can actually read street signs. After jacking with depinning for the switchbacks for a few minutes just cut wire. Figured I am never going back.
    SouthBoundSteve and ruiner[OP] like this.
  6. Mar 8, 2018 at 7:54 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Very nice!!!!
    SouthBoundSteve likes this.
  7. Mar 9, 2018 at 6:45 AM
    ruiner
    2017 Tundra CM 4x4
    Yeah, the Profile look just as good to be honest. Both are great solutions. As for de-pinning, I would have shown you a trick involving a thumb-tack. Oh well, maybe next time.
    I need to decide if I am going to do retro-fit LED fogs, 2018 OEM LED fogs, or just throw some LED bulbs into the housing (not sure if they would create any glare, but something to be aware of I guess).
  8. Mar 9, 2018 at 7:18 AM
    ruiner
    2017 Tundra CM 4x4
    Sure. To de-pin something in the harness, just a small flathead or something similar lift up the pin release. Then use a needle or thumbtack to push in and de-pin. The thumbtack is good because you can push on it easily to get pressure to push out the pin.
    Like so:
    bigalsnow and SouthBoundSteve like this.
  9. Dec 12, 2018 at 10:58 AM
    hudsonman44
    hudsonman44 New Member
    Aaron
    2016 Tundra CM TRD Pro
    I'm about to do a similar retrofit and was starting to look into the wiring. Did you have to splice the LED drivers into the existing harness?
  10. Dec 12, 2018 at 1:50 PM
    white_sherpa
    white_sherpa New Member
    Phoenix, AZ
    2014 Tundra SR5-Magnuson Supercharged- Custom Tune by DynoComp
    Turned out great! I love HID Projectors!
  11. Dec 12, 2018 at 2:35 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Wow those look great for Led projectors!
  12. Jan 6, 2019 at 3:21 PM
    lsumatt1514
    lsumatt1514 New Member
    2008 Tundra Crewmax Limited
    What model LED projectors were used in your retrofit and what is the color temperature? Any issues thus far?
    I'm getting a retrofit done soon, and trying to decide between an HID or LED projector and if I go LED, which model for them to use. Thanks!
    TRD-tv and Berdine like this.
  13. Mar 24, 2019 at 6:22 PM
    War_Wagon312
    War_Wagon312 Puddle Dodger
    Rich
    2016 Pro MGM CM
    Toyo MT 285/70/R18, led's all around, Baja Design squadron sport fogs, spider trax 1.5 spacers, led foot well lighting, interior chrome delete, kc hilites 40inch light bar grill mounted, 20%tint all around, color lugs black lugnut caps, 2019 pro head lights, led lights all around, spyder co tail lights, DMX1057xr, super crew box with kicker 10” sub,jbl door speakers, factory amp bypass trd air flow accelerator with drop in filter, x3 battery, Toyota bed cover, swing case,
    I de-pinned my amber DRLs on my 19 pro lights. I tried the thumbtac and Gorilla F#@&d the inside of the terminal and snapped the grey wire. Only plus was I was able to fit a small precision screw driver in there and get it out. Also threw the lasfit LEDs in for turn signal bulbs. They are pretty bright.
    Berdine likes this.
